Physical Therapy Project
2019-02-05T00:08:30+00:00
I am now starting a physical therapy project.
Here are my relationships so far:
So far the queries I have built are working good and giving me nice results.
My first question is basically about concatenating data.
Example 1:  I have 35 therapists. All therapists have at least one degree. About 16 therapists out of the 35 therapists have two or three degrees. What is the best way to concatenate their degrees?  By using the concatenate & in a string? My problem is that there are various amounts of degrees, so I'm not finding it easy to concatenate their degrees unlike their names - for example, FullName: [tFirst] & " " & [tLast] Or is there another way to handle this? I don't plan on creating a search by degree, but that may occur in the future.
Example 2:  The therapists and their Status. Some therapists are Per Diem (on call), some therapists are part time, and so on. Some therapists have more than one status (a few are part time and per diem). What's the best way to handle this so their status appears on one line? Would waiting until building the reports be best before handling this, and putting it in reports? I will be having a search by status, especially for the Per Diems therapists.
Example 3:  Some therapists work 1 day a week; some work 2 days; some 3; some 4; some 5; and some work 6 days a week. I have the days entered, but I won't get to building a table with therapists and their days until later. I'm assuming I will have to figure out a way similar to the above two examples to have the days show up nicely. Or should that also wait until I do reports? There will be a search for days by Therapy Type (ie, Physical Therapy, Occupational Therapy, Speech Therapy and Wound Therapy).
I hope my question is making sense. Thank you for your time and help.
Microsoft 365 and Office | Access | For home | Windows
2019-02-26T18:15:54+00:00
Hmm, just realized you need your WHERE statement to include both Visit and Clinic...
SELECT tblClinicTherapist.ctTherapistID, tlkpClinic.cName, [tFirst] & " " & [tLast] AS FullName
FROM (tlkpTherapist INNER JOIN (tlkpClinic INNER JOIN tblClinicTherapist ON tlkpClinic.cClinicID = tblClinicTherapist.ctClinicID) ON tlkpTherapist.tTherapistID = tblClinicTherapist.ctTherapistID) INNER JOIN tblClinicTherapistVisit ON tblClinicTherapist.ctClinicTherapistID = tblClinicTherapistVisit.ctvClinicTherapistID
WHERE (((tblClinicTherapistVisit.ctvVisitID)=[Forms]![frmSearch]![cboVisit]) AND ((tlkpClinic.cClinicID)=[Forms]![frmSearch]![cboClinic]))
ORDER BY tlkpTherapist.tLast;
59 additional answers
    2019-02-21T18:56:59+00:00
    I just changed the column count to 3 columns, with the first two set to 0 and it's still not working.
    I even double-checked the SQL was the same SQL as the one in the uploaded version and it's still not working either.
    2019-02-21T19:08:41+00:00
    Not sure, worked for me.  This is the SQL for the cboTherapist I used...
    SELECT tlkpClinic.cName, [tFirst] & " " & [tLast] AS FullName, tlkpVisit.vName FROM (tlkpTherapist INNER JOIN (tlkpClinic INNER JOIN tblClinicTherapist ON tlkpClinic.cClinicID = tblClinicTherapist.ctClinicID) ON tlkpTherapist.tTherapistID = tblClinicTherapist.ctTherapistID) INNER JOIN (tlkpVisit INNER JOIN tblClinicTherapistVisit ON tlkpVisit.vVisitID = tblClinicTherapistVisit.ctvVisitID) ON tblClinicTherapist.ctClinicTherapistID = tblClinicTherapistVisit.ctvClinicTherapistID WHERE (((tblClinicTherapistVisit.ctvVisitID)=[Forms]![frmSearch]![sfrVisitTherapist].[Form]![cboVisit])) ORDER BY tlkpTherapist.tLast;
    2019-02-21T19:31:35+00:00
    Thank you so much Gina. The SQL you provided worked. Sometimes I think I'm my own worst enemy when I get stuck. You are amazing, and I really appreciate all your time and help. Now on to the last item, then I'm officially done with this project, hopefully before the end of day tomorrow.
    2019-02-21T20:26:15+00:00
    Glad to help.
