Physical Therapy Project
2019-02-05T00:08:30+00:00
I am now starting a physical therapy project.
Here are my relationships so far:
So far the queries I have built are working good and giving me nice results.
My first question is basically about concatenating data.
Example 1:  I have 35 therapists. All therapists have at least one degree. About 16 therapists out of the 35 therapists have two or three degrees. What is the best way to concatenate their degrees?  By using the concatenate & in a string? My problem is that there are various amounts of degrees, so I'm not finding it easy to concatenate their degrees unlike their names - for example, FullName: [tFirst] & " " & [tLast] Or is there another way to handle this? I don't plan on creating a search by degree, but that may occur in the future.
Example 2:  The therapists and their Status. Some therapists are Per Diem (on call), some therapists are part time, and so on. Some therapists have more than one status (a few are part time and per diem). What's the best way to handle this so their status appears on one line? Would waiting until building the reports be best before handling this, and putting it in reports? I will be having a search by status, especially for the Per Diems therapists.
Example 3:  Some therapists work 1 day a week; some work 2 days; some 3; some 4; some 5; and some work 6 days a week. I have the days entered, but I won't get to building a table with therapists and their days until later. I'm assuming I will have to figure out a way similar to the above two examples to have the days show up nicely. Or should that also wait until I do reports? There will be a search for days by Therapy Type (ie, Physical Therapy, Occupational Therapy, Speech Therapy and Wound Therapy).
I hope my question is making sense. Thank you for your time and help.
Microsoft 365 and Office | Access | For home | Windows
2019-02-26T18:15:54+00:00
Hmm, just realized you need your WHERE statement to include both Visit and Clinic...
SELECT tblClinicTherapist.ctTherapistID, tlkpClinic.cName, [tFirst] & " " & [tLast] AS FullName
FROM (tlkpTherapist INNER JOIN (tlkpClinic INNER JOIN tblClinicTherapist ON tlkpClinic.cClinicID = tblClinicTherapist.ctClinicID) ON tlkpTherapist.tTherapistID = tblClinicTherapist.ctTherapistID) INNER JOIN tblClinicTherapistVisit ON tblClinicTherapist.ctClinicTherapistID = tblClinicTherapistVisit.ctvClinicTherapistID
WHERE (((tblClinicTherapistVisit.ctvVisitID)=[Forms]![frmSearch]![cboVisit]) AND ((tlkpClinic.cClinicID)=[Forms]![frmSearch]![cboClinic]))
ORDER BY tlkpTherapist.tLast;
59 additional answers
    2019-02-26T19:24:29+00:00
    Well, and I wasn't thinking BOTH combo boxes.  Was sipping my coffee when the light bulb went off.
    You're welcome!
    2019-02-27T15:53:50+00:00
    Thank you, thank you again so much Gina.
    I'll be so glad to be done with this project. Next one will be DI (Diagnostic Imaging - X-Rays, Ultrasound, CT Scan, MRI, etc). MS Access stuff is all I do now, which is fine, but am still looking for another job as eventually I will run out of projects and I don't know what will happen at that point. I am writing down what I have learned so far, and hopefully DI will be much easier.
    2019-03-04T04:51:36+00:00
    You are welcome.  And just think of all you've already learned!  No matter job you get next you can this knowledge with you.
