MS Project 2016 not saving custom field.
2018-11-30T07:02:00+00:00
Is anyone aware of an issue with MS Project 2016 where a custom field is not being saved?
The field is a flag one and is displayed as an image. If the value of the field is changed and the file is saved, when the file is re-opened the value has been brought back to its original value before the change. It works as expected in MS Project 2013.
Microsoft 365 and Office | Access | For home | Windows
    2019-01-09T15:03:41+00:00
    Hi Stanislava,
    After creating the custom field and adding the Flag1 column, set a value to the task. From the video, we see that you have not created a task and have not set a value to the task's Flag1.
    After setting it to Yes/No, save and close the file, then re-open the file and go to Custom Fields and change one of the No to a Yes. We suggest re-checking our video and follow the steps until we re-open the file.
    Regards,
    Sheen
    2019-01-10T15:11:15+00:00
    Hi Steen,
    Thank you for your message.
    The suggested workaround is behaving as expected when a new file is created and when the customized field and the task are also newly created.
    I am afraid that this is not a proper solution. There are a high number of already existing files and re-creating them is not an option. Could you advise further please?
    Kind regards
    Stanislava
    2019-01-11T12:33:38+00:00
    Hi Stanislava,
    Yes, this only applies when a new project is created. We understand that this still affects existing files and it would not be feasible to completely re-create each project.
    We'll let you know when we have any updates.
    Regards,
    Sheen
    2019-01-11T13:49:42+00:00
    Hi Steen,
    I look forward to hearing from you.
    Kind regards
    Stanislava
    2019-01-14T14:50:48+00:00
    Hi Stanislava,
    As we are also seeing the same behavior on our end, we have involved more resources to investigate. We'll let you know if we have an update.
    Regards,
    Sheen
