A family of Microsoft relational database management systems designed for ease of use.
Hi Stanislava,
After reviewing the issue, we see that you mentioned the saved project displays the value correctly on Project 2013 after being saved in Project 2016. This points to a display issue, as the value is actually correctly saved on the file, and only Project 2016 is continuing to show the wrong value.
As such, we would like you to try and disable the hardware acceleration option to see if this is related to your specific environment's graphics.
To do this, please navigate to File > Options > Advanced and tick the Disable hardware graphics accelerationoption under the Display sub-menu.
Regards,
Sheen
