Word Index Refer to Numbered List not Page
2018-12-31T03:02:04+00:00
I am asking this question, I don't think it is possible.  This is a 2 step question, assuming that the first one is not possible.
first question
I have a document with multiple pages.  Where, the document is made of numbered list for example
  1. word 1, word 2, word 3 etc.
  2. apple, orange, goat
  3. table, chair, mouse
  4. computer, printer, floor
I am building an index,
A
apple, 2
O
orange, 2
T
table, 3
as you can see rather refer to page number, the index will refer to the list instead.  I cannot find a way to do that or whether it can be done by macro.
2nd question, this should have been another question, but I put it here instead
assuming that question number 1 is not possible, then
I was looking the following article, try this macro but return the wrong number
https://wordmvp.com/FAQs/Numbering/ListString.htm
all what I need to do, from the list below
run a macro to get the list number.  for example, if I select "word 3" and run the macro, it will return "1"
as well as if I select "mouse" and run the macro it will return "3"
this is the simplest way, if 1 is not possible
Moved from: Office/ Word / Windows 10 / Office 2016
Paul Edstein 82,871 Reputation points Volunteer Moderator
2019-01-11T00:06:13+00:00
The code I posted inserts a PAGE field rather than just a page number. That approach allows for the possibility subsequent edits will result in the indexed content appearing on a different page.
2019-01-08T23:12:18+00:00
I don't get any such error when running the code. Are you using it exactly as posted and selecting the content to be indexed?
2019-01-25T23:03:30+00:00
I did say that would happen... See my reply of January 15.
2019-01-13T05:06:49+00:00
but that special character still shows up in the index when I insert the index at the end.
That was the intention. The non-breaking space doesn't print and, if you click on the ¶ symbol on the Ribbon's home tab, the symbol that looks like º will disappear.
2019-01-13T05:04:06+00:00
I think I can simply forget about the page number and rely with the paragraph number, since the paragraphs are numbered, so there is not need to go to specific page number
I think I should just forget about the page numbers.
Do be aware that, with the \t switch (which is what you need to report the paragraph #), the entries will be reported will be reported in descending order:
Apple. 2, 1
2019-01-12T07:15:55+00:00
Try:
Sub Demo()
Application.ScreenUpdating = False
ActiveWindow.View.ShowFieldCodes = True
With Selection
  ActiveDocument.Indexes.MarkEntry Range:=.Range, _
    Entry:=.Text & " PL", EntryAutoText:=.Text, Bold:=False, Italic:=False
  .End = .End + 1
  With .Fields(1).Code
    .End = .End - 2
    .Start = .End - 2
    .Font.Bold = True
    .Collapse wdCollapseEnd
    .InsertBefore Chr(160)
    .Font.Bold = False
    .Fields.Add Range:=.Duplicate, Type:=wdFieldEmpty, _
      PreserveFormatting:=False, _
      Text:="STYLEREF ""Default Paragraph Font"" \n"
  End With
End With
ActiveWindow.View.ShowFieldCodes = False
Application.ScreenUpdating = True
End Sub
This will produce:
Apple PL ‎1, 1
Apple PL ‎2, 2
Apple PL ‎3, 3
Apple PL ‎4, 5
Apple PL ‎5, 8
where the number after PL is the paragraph # and the number after the comma is the page #.
2019-01-11T22:48:41+00:00
That is not how an Index works. What you'd ordinarily get is something like:
A
Apple, 2, 3, 4, 5
where the numbers are page or paragraph references. To get what you want, every XE field would have to be unique, perhaps by including the PL & paragraph # in the XE field's argument, rather than as a switch.
2019-02-28T05:56:15+00:00
Try:
Sub Demo()
Dim Fld As Field, strnum As String
For Each Fld In ActiveDocument.Fields
  With Fld
    If .Type = wdFieldIndexEntry Then
      Do While .Code.Characters.Last = " "
        .Code.Characters.Last = vbNullString
      Loop
      Do While .Code.Characters.Last.Previous = "."
        .Code.Characters.Last.Previous = vbNullString
      Loop
    End If
  End With
Next
End Sub
51 additional answers
  1. Paul Edstein 82,871 Reputation points Volunteer Moderator
    2019-02-28T00:47:00+00:00
    I don't get an Index entry with Apple PL 5., 2 as a result of having a space before the } in {XE "Apple, PL 5" } - with or without that space I get an Index entry with 'Apple PL 5, 2'.
    The only ways I can get an Index entry with 'Apple PL 5., 2' are:
    • if there's a period after the 5 in the XE field (i.e. {XE "Apple, PL 5." }); or
    • by adding a switch like '\e "., "' to the INDEX field (i.e. {INDEX \e "., "}).
