Word Index Refer to Numbered List not Page
2018-12-31T03:02:04+00:00
I am asking this question, I don't think it is possible.  This is a 2 step question, assuming that the first one is not possible.
first question
I have a document with multiple pages.  Where, the document is made of numbered list for example
  1. word 1, word 2, word 3 etc.
  2. apple, orange, goat
  3. table, chair, mouse
  4. computer, printer, floor
I am building an index,
A
apple, 2
O
orange, 2
T
table, 3
as you can see rather refer to page number, the index will refer to the list instead.  I cannot find a way to do that or whether it can be done by macro.
2nd question, this should have been another question, but I put it here instead
assuming that question number 1 is not possible, then
I was looking the following article, try this macro but return the wrong number
https://wordmvp.com/FAQs/Numbering/ListString.htm
all what I need to do, from the list below
run a macro to get the list number.  for example, if I select "word 3" and run the macro, it will return "1"
as well as if I select "mouse" and run the macro it will return "3"
this is the simplest way, if 1 is not possible
Moved from: Office/ Word / Windows 10 / Office 2016
Paul Edstein 82,871 Reputation points Volunteer Moderator
2019-01-11T00:06:13+00:00
The code I posted inserts a PAGE field rather than just a page number. That approach allows for the possibility subsequent edits will result in the indexed content appearing on a different page.
2019-01-08T23:12:18+00:00
I don't get any such error when running the code. Are you using it exactly as posted and selecting the content to be indexed?
2019-01-25T23:03:30+00:00
I did say that would happen... See my reply of January 15.
2019-01-13T05:06:49+00:00
but that special character still shows up in the index when I insert the index at the end.
That was the intention. The non-breaking space doesn't print and, if you click on the ¶ symbol on the Ribbon's home tab, the symbol that looks like º will disappear.
2019-01-13T05:04:06+00:00
I think I can simply forget about the page number and rely with the paragraph number, since the paragraphs are numbered, so there is not need to go to specific page number
I think I should just forget about the page numbers.
Do be aware that, with the \t switch (which is what you need to report the paragraph #), the entries will be reported will be reported in descending order:
Apple. 2, 1
2019-01-12T07:15:55+00:00
Try:
Sub Demo()
Application.ScreenUpdating = False
ActiveWindow.View.ShowFieldCodes = True
With Selection
  ActiveDocument.Indexes.MarkEntry Range:=.Range, _
    Entry:=.Text & " PL", EntryAutoText:=.Text, Bold:=False, Italic:=False
  .End = .End + 1
  With .Fields(1).Code
    .End = .End - 2
    .Start = .End - 2
    .Font.Bold = True
    .Collapse wdCollapseEnd
    .InsertBefore Chr(160)
    .Font.Bold = False
    .Fields.Add Range:=.Duplicate, Type:=wdFieldEmpty, _
      PreserveFormatting:=False, _
      Text:="STYLEREF ""Default Paragraph Font"" \n"
  End With
End With
ActiveWindow.View.ShowFieldCodes = False
Application.ScreenUpdating = True
End Sub
This will produce:
Apple PL ‎1, 1
Apple PL ‎2, 2
Apple PL ‎3, 3
Apple PL ‎4, 5
Apple PL ‎5, 8
where the number after PL is the paragraph # and the number after the comma is the page #.
2019-01-11T22:48:41+00:00
That is not how an Index works. What you'd ordinarily get is something like:
A
Apple, 2, 3, 4, 5
where the numbers are page or paragraph references. To get what you want, every XE field would have to be unique, perhaps by including the PL & paragraph # in the XE field's argument, rather than as a switch.
2019-02-28T05:56:15+00:00
Try:
Sub Demo()
Dim Fld As Field, strnum As String
For Each Fld In ActiveDocument.Fields
  With Fld
    If .Type = wdFieldIndexEntry Then
      Do While .Code.Characters.Last = " "
        .Code.Characters.Last = vbNullString
      Loop
      Do While .Code.Characters.Last.Previous = "."
        .Code.Characters.Last.Previous = vbNullString
      Loop
    End If
  End With
Next
End Sub
51 additional answers
    2019-02-17T20:38:18+00:00
    I didn't want to start a new thread.  I think putting the question here, will probably get me an answer.
    I made a bit mistake, I wonder if it can be fix by a macro or I have to do it manually.  It will take me a long time to do it manually, because I have spent a lot of times in the document and I am in 3/4 of it.
    This is what happened, in some places in the document at the beginning somewhere in the 5th page, I have a paragraph that was not numbered or the number got removed by mistake.  All the paragraphs following that paragraph got improper paragraph number when I run the macro.
    The best way to fix that automatically is to run another macro, where that macro will check for the actual paragraph number and the number after the "PL" if they are not equal, then replace with proper paragraph number.   For example,
    1. some text {XE "some text PL 15"}
    when I run the macro, since 16 is the right number, then that will change the paragraph to
    1. some text {XE "some text PL 16"}
    this is he problem I try to solve.  The macro will loop through the document and make the change for me.  or when I click on a paragraph, the macro will recognize it and loop through that paragraph.
    any help?
