Power Query - Loop through unknown number of Tables and append them all - solved
2018-07-17T09:29:18+00:00
I have an Excel spreadsheet with a lot of columns but I want to save it in csv format with line breaks to put certain columns on different lines.   This is because I can upload different record types into my database but each record type needs its own line in csv with a header type as the first field on that line.
eg this in Excel:
col1   col2   col3   col4   col5   col6   col7   col8   col9   col10
01        b        c        d       e        02         g       h        03         j
01        r         s         t       u        02         v       w        03         x
becomes this in csv:
01, b, c, d, e
02, g, h
03, j
01, r, s, t, u
02, v, w
03, x
Is this possible?  Easy?
thanks
Louise
<The thread has been moved to the correct category by forum moderator>
Lz365 38,201 Reputation points Volunteer Moderator
2018-08-01T12:23:56+00:00
This is a very simplified version of this thread. We have an Input Table that looks like:
where each Group of colored columns needs to be transformed in a separate Table (so 3 in this case) and at the end we want the 3 Tables to be Appended (Combined according to Power Query M language)
Challenge
The number of Groups may vary (i.e. from 1 to say 10) from time to time. So we need a query that is flexible enough to handle this variation
Note
In the above example the 1st Group has 3 columns, the 2nd has 4 and the last has 5. To properly Append/Combine Tables they all must have the same number of columns. That aspect of the problem is not detailed in the below Power Query M snipet.
How To
Power Quey M language doesn't offer an easy way to loop. This example uses the List.Generate function to do that the appropriate number of times to build each Table and then Append/Combine them
let
    GroupsList = Record.ToList(Table.FirstN(Source, 1){0}),
    NbGroups = List.Count(List.Distinct(GroupsList)),
    // Loop (actually NbGroups of times) to create a Table for each "Group"
    // At the end we get a List that contains Table(s)
    The next Step will Append/Combine all Table(s)
    TablesToAppend = List.Generate(
         ()=> [i = -1, j = 0, OutputTable = #table({"Col","Index","Index2"},{})],
            each [i] < NbGroups,
                each
                        j = [j] +1,
                        ...,              // step1 to build the OutputTable
                        ...,              // step2 to build the OutputTable
                        TableIdx = ...,   // step3 to build the OutputTable
                        OutputTable = Table.AddIndexColumn(TableIdx, "Index2", j, 1),
                        i = [i] +1
                each [OutputTable]
    // Append all tables from above List
    TablesAppended = Table.Combine(List.Transform(TablesToAppend, each (_))),
in
59 additional answers
    2018-07-26T09:32:04+00:00
    Oh don't know why but by screen shot didn't capture the error message!!  I've redone it:
    https://www.dropbox.com/s/d3mu6g69469e3w5/Output%20error%20message.docx?dl=0
  2. Lz365 38,201 Reputation points Volunteer Moderator
    2018-07-26T09:52:31+00:00
    I see now ;-). I am not 100% sure but this seems to be a classic problem of Source unavailability (I don't have a server here to try replicating).
    You said earlier: I've saved both docs on my drive and you can see from the screen shot… and the Path to the INPUT file starts with **X:**.... Drive X: is rarely a local drive on a PC. More often it's a virtual drive mapped to a Server/OtherPC. And of course if - for whatever reason - the server isn't available you don't have access to its resources (files, printers…).
    To ensure we are not facing a Server/Resource unavailability issue I suggest you copy the INPUT & OUTPUT files to a drive that you're sure exist on your PC and try again
  3. Lz365 38,201 Reputation points Volunteer Moderator
    2018-07-26T10:10:48+00:00
    Just used another PC (running Windows 8.1) as a Server. Made 2 tests:
    1. Input file on the Server and Output file on my local drive => No issue
    2. Input AND Output files on the Server  => No issue
    2018-07-26T10:27:53+00:00
    I'm at work so the X drive is where I save things, but yes it is a network drive.  I've tried saving it on my desktop and got the same error message.
    Can the input table be another sheet in the same doc as the macro/output sheet rather than a separate doc?
    I have nowhere else to save things.  :0(
