Power Query - Loop through unknown number of Tables and append them all - solved
2018-07-17T09:29:18+00:00
I have an Excel spreadsheet with a lot of columns but I want to save it in csv format with line breaks to put certain columns on different lines.   This is because I can upload different record types into my database but each record type needs its own line in csv with a header type as the first field on that line.
eg this in Excel:
col1   col2   col3   col4   col5   col6   col7   col8   col9   col10
01        b        c        d       e        02         g       h        03         j
01        r         s         t       u        02         v       w        03         x
becomes this in csv:
01, b, c, d, e
02, g, h
03, j
01, r, s, t, u
02, v, w
03, x
Is this possible?  Easy?
thanks
Louise
<The thread has been moved to the correct category by forum moderator>
Lz365 38,201 Reputation points Volunteer Moderator
2018-08-01T12:23:56+00:00
This is a very simplified version of this thread. We have an Input Table that looks like:
where each Group of colored columns needs to be transformed in a separate Table (so 3 in this case) and at the end we want the 3 Tables to be Appended (Combined according to Power Query M language)
Challenge
The number of Groups may vary (i.e. from 1 to say 10) from time to time. So we need a query that is flexible enough to handle this variation
Note
In the above example the 1st Group has 3 columns, the 2nd has 4 and the last has 5. To properly Append/Combine Tables they all must have the same number of columns. That aspect of the problem is not detailed in the below Power Query M snipet.
How To
Power Quey M language doesn't offer an easy way to loop. This example uses the List.Generate function to do that the appropriate number of times to build each Table and then Append/Combine them
let
    GroupsList = Record.ToList(Table.FirstN(Source, 1){0}),
    NbGroups = List.Count(List.Distinct(GroupsList)),
    // Loop (actually NbGroups of times) to create a Table for each "Group"
    // At the end we get a List that contains Table(s)
    The next Step will Append/Combine all Table(s)
    TablesToAppend = List.Generate(
         ()=> [i = -1, j = 0, OutputTable = #table({"Col","Index","Index2"},{})],
            each [i] < NbGroups,
                each
                        j = [j] +1,
                        ...,              // step1 to build the OutputTable
                        ...,              // step2 to build the OutputTable
                        TableIdx = ...,   // step3 to build the OutputTable
                        OutputTable = Table.AddIndexColumn(TableIdx, "Index2", j, 1),
                        i = [i] +1
                each [OutputTable]
    // Append all tables from above List
    TablesAppended = Table.Combine(List.Transform(TablesToAppend, each (_))),
in
59 additional answers
    2018-07-19T15:02:15+00:00
    This has uploaded successfully.  :0)  I wasn't sure if all the commas at the end of rows would fail it as (eg) 00EMPLOYEE only has 6 columns and the csv conversion has obviously assumed the maximum number of columns for all record types/rows.  Well done!
    What next?
  2. Lz365 38,201 Reputation points Volunteer Moderator
    2018-07-19T16:51:02+00:00
    Hello Louise
    I was going to provide you the next steps but just discovered something I did not expect. I need to bit of time to workaround this with a couple of VBA lines of code. Expect news by this Friday
  3. Lz365 38,201 Reputation points Volunteer Moderator
    2018-07-20T05:15:15+00:00
    Hi Louise
    In this zipped file 2 files:
    • The INPUT one used for testing. Kind of template you will use for next exports. If you duplicate/modify it make sure the blue table is named TBL_INPUT as this info is hard-coded in the query
    • The OUTPUT one that contains the query, pulling info from the INPUT file. Self explainatory:
      • Enter the path & file name to the INPUT file in I2 (info dynamically passed to the query)
      • Click the macro button on the left to Refresh the query and create a new workbook that will contain a copy (without the table header) of the OUTPUT sheet
    2018-07-20T07:47:36+00:00
    Great, thanks.  I'll give it a go later.
