Display Problem with OneNote app
2018-10-15T23:23:57+00:00
I have a new Thinkpad P1 with the Nvidia P2000 Discrete Graphics card onboard. I have this following display/screen drawing issue with OneNote app (and only this app)
I have tried using the disableonenotehardwarerenderingx64 utility from Microsoft, but this did not resolve the issue.
Any ideas out there?
David
2019-06-13T12:24:31+00:00
Through my support request with Nvidia's Customer Help system (the link Rena provided), I was informed that the driver I had installed was no longer the latest version.
They referred me to the Quadro driver release #430, dated June 10, 2019.
I've only done a few tests, but it looks like the driver has addressed the issue.  I do not get the same video corruption in OneNote anymore.
2019-06-03T06:26:24+00:00
Hi All,
Thanks for your effort and time on this case. We are sorry for the inconvenience the issue causes. We have reported and got the response from the related resource. However, it is still recommended to submit a bug report to Nvidia directly. I'd like to share a summary for the issue here which will benefit other community members.
Symptoms:
OneNote for Windows 10 app will have display issue if the computer is using Nvidia graphic card.
Environment:
The computer is running with Nvidia graphic card.
OneNote for Windows 10 app.
Workaround:
It seems that the issue only happens in OneNote for Windows 10 but not OneNote 2016. As a workaround, please refer to Install or reinstall OneNote 2016 for Windows for your need.
Assessment:
The issue is caused by the conflict between OneNote app and Nvidia graphic card. After confirming with the related resource, it is recommended to first submit a bug report to Nvidia directly here.
Sorry for the inconvenience. You can use the workaround mentioned above temporarily. If you still have any concern about this, you can go to OneNote for Windows 10 app > click the “…” collapse settings button on the right corner of the window > Feedback to post your feedback directly. We appreciate your understanding.
Best Regards,
Rena
43 additional answers
    2018-10-19T10:33:09+00:00
    Hi David,
    We understand your concerns.
    Given the situation, I would like to consult the related team to involve more resource to help check the issue. Once I get any update, I will post back and let you know.
    In the meantime, I would like to collect your account information viaprivate message.
    Regards,
    Eli
    [Updated by Eli Qian MSFT,  12:53 PM, Oct 19 , 2018 (UTC)]
    2018-10-22T23:47:26+00:00
    Hi David,
    We haven't hear back from you. If you need further assistance, please help provide the information mentioned.
    Regards,
    Eli
    2018-10-24T05:26:19+00:00
    Hi Eli
    I will provide the additional information in the next day.
    David
