Display Problem with OneNote app
2018-10-15T23:23:57+00:00
I have a new Thinkpad P1 with the Nvidia P2000 Discrete Graphics card onboard. I have this following display/screen drawing issue with OneNote app (and only this app)
I have tried using the disableonenotehardwarerenderingx64 utility from Microsoft, but this did not resolve the issue.
Any ideas out there?
David
2019-06-13T12:24:31+00:00
Through my support request with Nvidia's Customer Help system (the link Rena provided), I was informed that the driver I had installed was no longer the latest version.
They referred me to the Quadro driver release #430, dated June 10, 2019.
I've only done a few tests, but it looks like the driver has addressed the issue.  I do not get the same video corruption in OneNote anymore.
2019-06-03T06:26:24+00:00
Hi All,
Thanks for your effort and time on this case. We are sorry for the inconvenience the issue causes. We have reported and got the response from the related resource. However, it is still recommended to submit a bug report to Nvidia directly. I'd like to share a summary for the issue here which will benefit other community members.
Symptoms:
OneNote for Windows 10 app will have display issue if the computer is using Nvidia graphic card.
Environment:
The computer is running with Nvidia graphic card.
OneNote for Windows 10 app.
Workaround:
It seems that the issue only happens in OneNote for Windows 10 but not OneNote 2016. As a workaround, please refer to Install or reinstall OneNote 2016 for Windows for your need.
Assessment:
The issue is caused by the conflict between OneNote app and Nvidia graphic card. After confirming with the related resource, it is recommended to first submit a bug report to Nvidia directly here.
Sorry for the inconvenience. You can use the workaround mentioned above temporarily. If you still have any concern about this, you can go to OneNote for Windows 10 app > click the “…” collapse settings button on the right corner of the window > Feedback to post your feedback directly. We appreciate your understanding.
Best Regards,
Rena
43 additional answers
    2019-06-07T04:13:06+00:00
    Given that pretty much everything else that I run does not have this issue, what is OneNote doing that triggers this behavior?
    I just recently migrated to a my new workstation and not being able to use OneNote well is having an impact on my productivity.  I did upgrade the driver to the most recent release for the P2000 today; but the issue remains.
    Thank you.
    2019-06-07T07:07:31+00:00
    Hi Toybuilder,
    Sorry to hear you are encountering the same issue. Just like the summary I posted, the issue is caused by the conflict between Nvidia graphic card and OneNote for Windows 10 app. Updating the driver can’t help.  We recommend submitting a bug report to Nvidia directly here.
    It seems that the issue only happens in OneNote for Windows 10 but not OneNote 2016. As a workaround, please refer to Install or reinstall OneNote 2016 for Windowsfor your need.
    Rena
    2019-06-13T15:07:33+00:00
    Hi Toybuilder,
    Thank you so much for posting this information here. This may help other community members. I will mark this as answer to let other members to see it easily.
    Best Regards,
    Rena
