AutoSave switch greyed-out.
2017-08-04T15:40:16+00:00
A couple of days ago, I noticed that the save icon at the top of the Excel window in version 1707 of Office 365 has been moved a little to the right because a new greyed-out AutoSave button has appeared. It is set to "Off".
Does anyone know how to turn it on?
2017-08-04T16:25:12+00:00
this is from:
https://support.office.com/en-us/article/What-is-AutoSave-6d6bd723-ebfd-4e40-b5f6-ae6e8088f7a5?ui=en-US&rs=en-US&ad=US
"AutoSave is enabled when working on a file that is saved to OneDrive, OneDrive for Business, or SharePoint Online. If the file is saved to another location, then AutoSave is disabled. This will happen if your file is on a SharePoint On Premises site, a file server, or saved to a local path like C:.
There are other reasons AutoSave could be disabled as well. For example, if your file is in an older format like .xls, .ppt, or .doc., it will be disabled. It will also be disabled if your presentation is in slide show mode, or if your workbook contains password protection. If AutoSave is disabled, you can always hover over the AutoSave switch and a tooltip will tell you why it's off."
49 additional answers
    2018-02-18T22:01:38+00:00
    this is from:
     Well that's not a very helpful approach when USERS for the past 25 years have been allowed to set auto-save and recovery of files to a local disk location to protect their work from unexpected system problems, like the software you own not saving the files where you want them to be saved in the format you want them saved in.
    I've been a Microsoft applications user since 1985, yes, 1985.  Only with the new Office 365 versions are we seeing the protection mode of auto-save no longer a user feature but in turn being a Microsoft management feature.  How is this a good idea, what are you thinking?
    2018-02-20T11:35:19+00:00
    this is from:
    "A tooltip will tell you why its off" ...works great :)
    My Document is saved to Sharepoint online or OneDrive
    2018-02-20T16:51:17+00:00
    this is from:
    J.B.  I get what you did there, you redirected what I specifically said was a problem with a feature that had previously been working just fine for over 25 years that now REQUIRES the use of cloud services from Microsoft... well played sir.. well played...
    Unfortunately you've only repeated what other non-supportive and unhelpful responders have done before you, i.e. not provided an original or useful response.  I'm not intending to disparage you and I respect your response, I and others like me won't find it helpful.
    You must understand there are a very large majority of product users who do not want to always require connection to their "one-drive" which has a local and a cloud component with "auto-save" functional recovery.  Yes, one-drive has a local drive component and a cloud based component {insert quote from Microsoft "for protecting needed files"}.  However I may not like or want to use One-Drive and only want to use my OWN disk where I don't have the potential of all of my files being captured by big corporate who "never" does anything wrong or illicit with customer files.
    This is tantamount to saying someone who wants to have a survival kit for their home in case of disaster must use the disaster services warehouse NOT AT THEIR HOUSE to keep a disaster survival kit.  How wrong is wrong?...
    2018-02-20T18:47:14+00:00
    Want to get rid of Autosave?  Then go to Feedback Hub and upvote the topic I just posted there. That is the way to get Microsoft to actually take notice. (You'd think they would pay attention in these forums also, but apparently they don't.)
    In Feedback Hub, search for this topic by typing some or all of the summary title in the Summarize-your-issue box: "Autosave is redundant, confusing, and useless. And it doesn't work. Delete this feature."
    Once finding it, upvote it.  Feel free to add comments there as well.  Apparently activity there counts more than activity here.  Dumb, but that's Microsoft for ya.
    (I just posted it - may take a while to show up there.)
