A family of Microsoft products that enable users to capture, organize, and reuse notes electronically.
Luke,
Per my earlier note, here are a couple of links to try. Both worked OK using Chrome and the "Article" option:
https://www.huffingtonpost.com/entry/opinion-lenz-billy-graham_us_5a8ef291e4b005bb0fef46ec
https://www.yahoo.com/news/tucker-carlson-turns-trump-apos-095039632.html
These are the Huffington Post and Yahoo. The first link I sent to you was for MSN.
Following is a link from CNBC that doesn't work:
Generally speaking, I've found that sites either work or they do not. I don't recall having any problems with MSN or Yahoo, for example. I did a couple of quick tests today and the Huffington Post appears to be solid, as well. CNBC on the other hand has never worked as far as I can recall.
This is what makes me think the problem has something to do with the technology used by each website. If you and/or some of your students are particularly techie you may be able to look at the website information (usually readily available in the browser) and draw some conclusions as to what development platform was used.
The following article, for example, provides information on how to access web page source code.
https://blog.kissmetrics.com/how-to-read-source-code/
Delving into that is above my pay grade, for sure.
Wayne
