A family of Microsoft spreadsheet software with tools for analyzing, charting, and communicating data.
I think this does it....
I need another formula that take the individual's score on a hole, converts it to a STABLEFORD format (ex: DOUBLE BOGEY = 0 pts; BOGEY = 1 pt; PAR = 2 pts; BIRDIE = 3 pts; EAGLE = 4 pts; DOUBLE EAGLE = 8 pts). So if an individual shoots a "4" on a PAR 4 hole, he would get "2 pts" for his team.
So the formula would have to identify the following(all within the same formula because the 3 or 4 team members could shoot different scores:
(PAR = required total number of strokes for that hole)
EVEN PAR = 2 pts
+1 over PAR = 1 pt
+2 over PAR = 0 pts
EXAMPLE on spreadsheet:
TEAM #1 PAR (4) TM PTS
Player A 4 6
Player B 3 7
Player C 5 1
Player D 6 0
Formula needs to populate the "TM PTS" cells with the STABLEFORD scores established from the PAR cells score
You could use a formula like this for column C, where the scores are given in rows 3 to, let's say, 20, and names are in column A.
=IF(COUNTIF(C3:C20,MIN(C3:C20))=1,INDEX($A3:$A20,MATCH(MIN(C3:C20),C3:C20,False),"")
If two people shoot the same lowest score the cell will remain blank. IF you have more rows (or fewer) adjust the 20 in all places.
You can copy this formula to the other 17 columns to identify the best player.
As for the low net, is that adjusted for handicap, or is it on a straight lowest strokes basis? If you have a column where the net is summed for each player, then the formula above will give the name of the lowest based on that column.
Either this:
=144-SUM(A2:A4)/2
or
=(144-SUM(A2:A4))/2
depends on what you divide by two - the sum of the team handicap, which is then subtracted from 144, or 144 minus the sum of the team handicap.
Cell D8 is the rollup for the hole for the 4 team members:
=IF(D4-D$1>=2,0,IF(D4-D$1<=-3,8,D$1-D4+2))+IF(D5-D$1>=2,0,IF(D5-D$1<=-3,8,D$1-D5+2))+IF(D6-D$1>=2,0,IF(D6-D$1<=-3,8,D$1-D6+2))+IF(D7-D$1>=2,0,IF(D7-D$1<=-3,8,D$1-D7+2))
Which is copied to the right for the other 17 holes (E8:U8), and B8 just has
=SUM(D8:U8)
Here's a file with a working formula and layout:
If you have different pars on different holes, then you need to have a column for those 18 values.
Let's say that par for the hole 1 is in B2, hole 2 in C2 (and so on across the row) and the first player's scores start in cell B3 and continue across Row 3, second player is in row 4, and so on...
This formula will give the points for the first player on hole 1, and can be copied across to match all 18 holes, and down to match all your players, converting all the scores to points:
=IF(B3-B$2>=2,0,IF(B3-B$2<=-3,8,B$2-B3+2))
| TEAM #1 | HDCP | HOLE #1 |
| Player A | 5 | 4 |
| Player B | 9 | 0 |
| Player C | 13 | 3 |
| Player D | 19 | 0 |
| TEAM HOLE PTS (STABLEFORD) | 2 |
this is what a section of the spreadsheet looks like. I want the cells for the holes to show the actual scores and the cell that represents the Team Hold Pts (STABLEFORD) to show the STABLEFORD Pt roll-up for all 4 players
I think the problem with mine is that your formula indicates that B$2 represents what the PAR Score is for that particular hole and my layout does not recognize what the PAR Score actually is. I do have a section that has the PAR Score for each hole. I think all I need to do is replace your B$2 with my cell # that represents PAR for that particular hole.
your thoughts!
