Configuring EXCEL spreadsheet for a men's golf association BLITZ format #2
2017-11-08T17:38:25+00:00
I need another formula that take the individual's score on a hole, converts it to a STABLEFORD format (ex: DOUBLE BOGEY = 0 pts; BOGEY = 1 pt; PAR = 2 pts; BIRDIE = 3 pts; EAGLE = 4 pts; DOUBLE EAGLE = 8 pts).  So if an individual shoots a "4" on a PAR 4 hole, he would get "2 pts" for his team.
So the formula would have to identify the following(all within the same formula because the 3 or 4 team members could shoot different scores:
(PAR = required total number of strokes for that hole)
  • 2 below PAR = 4 pts
  • 1 below PAR = 3 pts
EVEN PAR = 2 pts
+1 over PAR = 1 pt
+2 over PAR = 0 pts
EXAMPLE on spreadsheet:
TEAM #1               PAR (4)           TM PTS
Player A                   4                        6
Player B                   3                        7
Player C                   5                        1
Player D                  6                         0
Formula needs to populate the "TM PTS" cells with the STABLEFORD scores established from the PAR cells score
2017-11-09T16:07:53+00:00
You could use a formula like this for column C, where the scores are given in rows 3 to, let's say, 20, and names are in column A.
=IF(COUNTIF(C3:C20,MIN(C3:C20))=1,INDEX($A3:$A20,MATCH(MIN(C3:C20),C3:C20,False),"")
If two people shoot the same lowest score the cell will remain blank. IF you have more rows (or fewer) adjust the 20 in all places.
You can copy this formula to the other 17 columns to identify the best player.
As for the low net, is that adjusted for handicap, or is it on a straight lowest strokes basis? If you have a column where the net is summed for each player, then the formula above will give the name of the lowest based on that column.
2017-11-08T20:40:18+00:00
Either this:
=144-SUM(A2:A4)/2
or
=(144-SUM(A2:A4))/2
depends on what you divide by two - the sum of the team handicap, which is then subtracted from 144, or 144 minus  the sum of the team handicap.
2017-11-08T20:19:16+00:00
Cell D8 is the rollup for the hole for the 4 team members:
=IF(D4-D$1>=2,0,IF(D4-D$1<=-3,8,D$1-D4+2))+IF(D5-D$1>=2,0,IF(D5-D$1<=-3,8,D$1-D5+2))+IF(D6-D$1>=2,0,IF(D6-D$1<=-3,8,D$1-D6+2))+IF(D7-D$1>=2,0,IF(D7-D$1<=-3,8,D$1-D7+2))
Which is copied to the right for the other 17 holes (E8:U8), and B8 just has
=SUM(D8:U8)
2017-11-08T19:21:48+00:00
Here's a file with a working formula and layout:
https://1drv.ms/x/s!AsKdy7Nfg\_FbgmqX3eyOEAhX6kaF
2017-11-08T17:54:08+00:00
If you have different pars on different holes, then you need to have a column for those 18 values.
Let's say that par for the hole 1 is in B2, hole 2 in C2 (and so on across the row) and the first player's scores start in cell B3 and continue across Row 3, second player is in row 4, and so on...
This formula will give the points for the first player on hole 1, and can be copied across to match all 18 holes, and down to match all your players, converting all the scores to points:
=IF(B3-B$2>=2,0,IF(B3-B$2<=-3,8,B$2-B3+2))
56 additional answers
    2017-11-09T18:37:08+00:00
    I guess I should have added:
    if two or more on the same team birdie the same hole, I only need one name to show up. we can figure out the team easily enough.
    2 birdies trumps 1 birdie; 3 birdies trumps 2 birdies. formula would need that info to figure out what team actually won the hole
    if there are ties on # of birdies per hole by teams, then cell is left blank
