MS Word 2016 Alt-Click on a word to open Research Bug
2018-01-28T21:55:02+00:00
Alt-Click is not working in Word 2016 but it still works in Outlook 2016 and all the other Office applications with that use the Research pane. It works in my old office 2007-2010 Word. How do I get it back.?
_______________________________
Still no way to fix this bug.
Microsoft broke the feature with their new modern Translator feature and did not give any notice of it or a way to fix it and it still works in all the rest of the Office apps. There are some suggested workarounds for the bug but they don't work on my PC. There is no way I can see to add the Alt+Click shortcut and the Group Policy change did not remove new the modern Translator feature.
___________________________________
Suggested workarounds, maybe someone else can get them to work.
If you still need or rely on the Alt+Click shortcut for Research pane, there are a few possible workarounds:
    2018-05-24T16:40:02+00:00
    Sorry Tnakequen1.
    I did as you said:
    Research window on Alt-Click in Word 2016 makes block selection impossible
    My last post here!
  2. Suzanne S Barnhill 279.4K Reputation points MVP Volunteer Moderator
    2018-05-24T16:43:26+00:00
    It requires practice, but it works for me. I use it regularly.
    2018-06-20T14:55:21+00:00
    Still not Alt-Click fix. I'm keeping Office 2010 for now. I hope they put it back or add a workaround that, well, works.
    2018-06-24T20:22:58+00:00
    I read this thread from start to finish because I, too, mourn the loss of Alt + Click to quickly access the Thesaurus. Shift + F7 just isn't the same.
    Thank you, Beth for your excellent sleuthing and Tanquen1 for your persistence.
  5. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2018-06-24T21:36:20+00:00
    Right click and then click on Smart Lookup
