A family of Microsoft word processing software products for creating web, email, and print documents.
Try using a STYLEREF field.
I have a Word 2016 document with 6 sections in it. Each section contains 3 tables. It's possible for the tables to span more than one page. When they do, I'd like to repeat the section header at the top of the second page, with " (continued)" tacked onto the end of the header. I looked at "fields" for this, but I don't see that level of customization. Can anyone suggest what Word features I should use to create this effect?
Note that you don't need sections to format a text range as hidden. For example, if you enclose a range in a bookmark, you can use similar code to hide the range defined by the bookmark:
ActiveDocument.Bookmarks("BookmarkName").Range.Font.Hidden = True
The best approach will, of course, depend on what you are trying to accomplish in the end.
A little late, but instead of using STYLEREF fields, you might be able to use the general approach I describe in the sample document at https://goo.gl/2vsL8E
Is this the same as Collapsed sections?
Hidden Sections aren't the same as Collapsed. I'm using the command
wrdDoc.Section(i).Range.Font.Hidden = True
If a StyleRef Field refers to text that has been marked as hidden, it will show as blank.
StyleRef field does not work with hidden text
Useful StyleRef tricks by Suzanne Barnhill (Figure 7)
In other words, if following the rules for which text is found by a StyleRef field, Word encounters text in the document that has been marked as hidden, it uses that text, but does not display it. It does not find the next instance of the style that is unhidden.
I believe that is the source of your problem.
Note that hidden text is not gone. It is there.
I generally have Word set to display hidden text. You have no control over whether or not the user displays hidden text.
I would urge you to explore Peter's work. I do not know if it will do what you want.
