word document - how to create custom section headers?
2017-08-17T16:37:36+00:00
I have a Word 2016 document with 6 sections in it. Each section contains 3 tables. It's possible for the tables to span more than one page. When they do, I'd like to repeat the section header at the top of the second page, with " (continued)" tacked onto the end of the header. I looked at "fields" for this, but I don't see that level of customization. Can anyone suggest what Word features I should use to create this effect?
Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
2017-08-21T23:43:35+00:00
Try using a STYLEREF field.
43 additional answers
  1. Stefan Blom 353.6K Reputation points MVP Volunteer Moderator
    2017-08-18T21:58:42+00:00
    There is no simple way to do what you want, but there is a somewhat clumsy workaround...
    What you can do is add an ordinary repeated header to the table, include "(continued)" and, on the first page of the table, cover it with a text box. Note that you mustn't anchor the text box to the repeated table header, of course.
    2017-08-18T13:07:12+00:00
    I've also looked at modifying the Style for Heading 1, but again, I don't see such customization for heading styles.
  3. Deleted
