No longer able to digitally sign VBA code in Excel 2016
2017-05-01T19:09:15+00:00
Hello all!
I have a DigiCert issued code signing certificate that I have been able to use from January 2017 up until two weeks ago (about the time of the Creator's Update for Windows 10 Pro). The Cert is valid through 2020. Unfortunately, I when I try to sign VBA code with it now, I get the error message "There was a problem with the digital certificate. The VBA project could not be signed. The signature will be discarded.
Is anyone else getting this message when signing VBA code with a Cert that previously worked?
I was able to test on a co-worker’s computer running
OS: Windows 7 Pro SP1
Office: Office 365 ProPlus Ver 1701 (build 7766.2076).
I was able to successfully sign a macro file on this machine.
My computer is running
OS: Windows 10 Pro version 1703 (build 15063.250)
Office: Office 365 Ver 1701 (Build 7967.2139)
I am not able to successfully sign a macro file on my machine. I am able to successfully import the certificate though.
DigiCert of course blames the issue on Microsoft, and given that I can successfully sign on my co-worker's Windows 7 machine with a slightly older build of Office 365, I wonder if something  in the newer version of Office 365 broke the ability to sign VBA macros.
Thanks - Nate
2017-08-03T18:12:15+00:00
Hi StephenGibb,
My re-installation must have missed the August updates you mention by a whisker. I forced an update just now, 1707 Build 8326.2062 is now my version. And, thankfully, it works!
Some extra info about when the problem was occurring for anyone else who might come across this thread:
As well as the failure to sign a project, Office was silently disabling all signed macros, not just those in the locations I mentioned above.
50 additional answers
    2017-10-02T14:09:51+00:00
    Turns out we were on the 'Deferred Channel'. Now changed and the build went up to 1708 and the VBA signature problem has sorted itself out. Thanks very much for pointing that out! All sorted!
    2017-10-02T14:11:10+00:00
    Is it not updating when you go to "File", "Office Account", "Office Updates" button in the middle of the page?
    Also, I have Office 365, 64-bit installed (instead of the default 32-bit).
