MS Word 2016 comment bubbles not numbered
2016-11-17T18:10:54+00:00
I am using MS Office 2016 and it seems that comment bubbles are no longer numbered like they were in previous versions. When a reviewer using an older version of Word refers to a specific comment by its number, I cannot tell which comment they are referring to because the comments are not numbered in Word 2016. Does anyone know why this feature was removed or how to fix it? It is extremely frustrating that the numbering of comments has been removed. Thank you,
Stefan Blom 353.6K Reputation points MVP Volunteer Moderator
2016-11-17T19:42:44+00:00
In Word 2016 (and 2013), comment numbers only display when you look at the print preview (at File | Print) or when you print the document, unfortunately. As a workaround, you can apply paragraph numbering to the Comment Text style.
41 additional answers
    2018-05-07T14:47:00+00:00
    That is actually what I want. Do you have a macro and loading instructions to do this?
    Thanks much,
    Gayle
  2. Stefan Blom 353.6K Reputation points MVP Volunteer Moderator
    2018-05-07T14:50:42+00:00
    I can create such a macro, but I don't know if it is going to work in Word for Mac.
    2018-05-07T15:06:26+00:00
    Any help you could try to offer would be greatly appreciated. Thanks in advance,
    Gayle
  4. Stefan Blom 353.6K Reputation points MVP Volunteer Moderator
    2018-05-07T18:42:56+00:00
    You can run this macro manually to apply Arabic style numbering to the Comment Text style (applies to the currently active document in Word):
    Sub ModifyCommentStyle()
    'Comment Text numbering macro created by MVP Stefan Blom
    'Tested in Word for Windows
    Dim s As Style
    Dim lt As ListTemplate
    On Error GoTo errhandler
    Set lt = ActiveDocument.ListTemplates.Add(OutlineNumbered:=False)
    With lt
    .ListLevels(1).NumberStyle = wdListNumberStyleArabic
    End With
    Set s = ActiveDocument.Styles(wdStyleCommentText)
    With s
    s.LinkToListTemplate lt
    End With
    errhandler:
    Exit Sub
    End Sub
    In Word for Windows, you can change the name of the macro from ModifyCommentStyle to AutoOpen and the macro will run for every document that you open in Word. However, I am not sure if so-called auto macros are supported in Word for Mac.
