MS Word 2016 comment bubbles not numbered
2016-11-17T18:10:54+00:00
I am using MS Office 2016 and it seems that comment bubbles are no longer numbered like they were in previous versions. When a reviewer using an older version of Word refers to a specific comment by its number, I cannot tell which comment they are referring to because the comments are not numbered in Word 2016. Does anyone know why this feature was removed or how to fix it? It is extremely frustrating that the numbering of comments has been removed. Thank you,
Stefan Blom 353.6K Reputation points MVP Volunteer Moderator
2016-11-17T19:42:44+00:00
In Word 2016 (and 2013), comment numbers only display when you look at the print preview (at File | Print) or when you print the document, unfortunately. As a workaround, you can apply paragraph numbering to the Comment Text style.
41 additional answers
    2017-05-23T01:41:25+00:00
    Thanks Doug. I voted at http://word.uservoice.com/.
  2. Stefan Blom 353.6K Reputation points MVP Volunteer Moderator
    2017-05-23T09:14:07+00:00
    Doug, perhaps you could also repost the macro you created about a month ago, in case someone wants to try it.
    2017-12-04T22:58:19+00:00
    But in a Mac, which my daughter uses, the comments are all numbered in her doc view.
  4. Stefan Blom 353.6K Reputation points MVP Volunteer Moderator
    2017-12-04T23:10:38+00:00
    Note that this thread only deals with Office for Windows. Personally I have never used Word for Mac, so I am not familiar with it.
    It is true that even Word for Windows displays the user initials plus comment number in a printout (and in the preview at File | Print).
