MS Word 2016 comment bubbles not numbered
2016-11-17T18:10:54+00:00
I am using MS Office 2016 and it seems that comment bubbles are no longer numbered like they were in previous versions. When a reviewer using an older version of Word refers to a specific comment by its number, I cannot tell which comment they are referring to because the comments are not numbered in Word 2016. Does anyone know why this feature was removed or how to fix it? It is extremely frustrating that the numbering of comments has been removed. Thank you,
Stefan Blom 353.6K Reputation points MVP Volunteer Moderator
2016-11-17T19:42:44+00:00
In Word 2016 (and 2013), comment numbers only display when you look at the print preview (at File | Print) or when you print the document, unfortunately. As a workaround, you can apply paragraph numbering to the Comment Text style.
41 additional answers
    2018-05-08T18:23:59+00:00
    OK will do. No error..just did nothing.
    2018-06-19T06:57:06+00:00
    Yes, I've just switched to Word 2016 at my university job. This is very frustrating. I used the referral to comments numbers as in the question here routinely in comments on student work. Using paragraph numbering is clumsy and not very helpful. The numbering needs to come back
    2018-06-19T07:00:43+00:00
    AMEN! MS has been 'evaluating' comments from the MANY of us that have been writing in. This  'evaluation' has been going on for months with still no help in sight!
  4. Stefan Blom 353.6K Reputation points MVP Volunteer Moderator
    2018-06-19T07:12:22+00:00
    I agree that using paragraph numbering is a bit clumsy; after all, it is a workaround (which has been required since comment numbering was re-designed in Word 2013).
    Doug's macro from 2017 does a better job:
    Sub NumberComments()
    'Macro created by MVP Doug Robbins, April 2017
    Dim i as Long
    Dim rngComment as Range
    With ActiveDocument
        For i = 1 to .Comments.Count
            Set rngComment = .Comments(i).Range
            With rngComment
                If Left(.Text, 7) = "Comment" Then
                    .Text = "Comment " & i & " " & Mid(.Text, Instr(.Text, "-"))
                Else
                    .Text = "Comment " & i & " - " & .Text
                End If
            End With
        Next i
    End With
    End Sub
    The macro can be run repeatedly to update the numbering.
