A family of Microsoft word processing software products for creating web, email, and print documents.
Yes, that's my experience also Maria, unchecking "Read Only" does nothing.
I'm sick of office locking my files to Read Only.
I have files I use all the time in my one drive folder, I'll open one and word decides it is Read Only and to make a change I need to save it as a new name.
I email a file to my wife to read, she makes changes and emails it back...now its Read Only.
How do disable this frustrating crap interfering with my workflow? It's making me crazy!!!
If you right-click the icon for a problem document, click Properties on the context menu and, in the Properties window, click Unblock and Apply, does that fix the problem?
Documents saved to the C: drive shouldn't be read-only. Are you saying that this happens when you re-open a document that was saved from within Word?
in short - yes.
I right click on a single document or a folder, click properties, uncheck read-only and apply. It fixes the problem until I next try to access a document in that folder or the document I just unchecked. When I try to open it the next day or later in the day it is read only again.
All the documents in these folders are saved from within Word.
Ok... so what does that mean and how to I find file permissions?
