OneNote 2016 Application issue with "Quick Notes" stuck loading
2016-06-24T12:13:30+00:00
Hi Guys,
Every time I try to access my "Quick Notes" this is what I get. It stays stuck there forever. Is there a way to fix this?
2016-11-14T20:26:34+00:00
Hi everyone,
Some news - a fix for this issue has been released with update 16.0.7466.2038 or later for OneNote 2016 for Windows desktop. To download the update right away, open any Office app and click File > Account > Update Options >
Update Now.
If you can confirm the updated resolved the issue for you by replying back to this thread, it would be very helpful for the Office team and everyone here.
We appreciate your help.
Regards,
Noyonima
2016-10-07T20:46:26+00:00
Hi everyone,
OneNote team had finished the investigation of this issue. There will be a updated version of OneNote 2016 that contains solution to this. Also, we have published an article documenting  way to work around the problem, should you experience it: https://support.office.com/article/d1e0568b-19f0-4fe7-adb0-923ed60a3587
Thank you for using OneNote and sorry for the trouble this issue is causing.
45 additional answers
    2016-06-25T00:21:22+00:00
    Hello Jeremie,
    Let's refer to the following article which discusses about the similar issue and see if it helps
    http://answers.microsoft.com/en-us/office/forum/office_2013_release-onenote/quick-notes-wont-sync-to-folder/fe730230-8dd9-4003-8173-2c50fec2cdad
    Hope it helps. I look forward to your reply to assist you further.
    Thank you.
    2016-06-26T02:36:37+00:00
    I have tried the steps above but I am stilling getting the same issue. When I open one note and select "Quick Notes" at the bottom of the window it still gets stuck.
    2016-06-29T19:49:44+00:00
    I had the same problem. This is what worked for me: I closed all notebooks. When I restarted Onedrive, Quick Notes loaded normally. Finally, I just reopened all my notebooks.
