"there's a problem with the clipboard, but you can still paste this content within this workbook"
2016-11-17T14:55:36+00:00
Perhaps someone could direct to a discussion where this has been tackled, but I keep getting this error "there's a problem with the clipboard, but you can still past this content within this workbook " with simple cut/copy and paste actions in Excel.  The error box pops up and an alert sounds (which is super annoying) after every paste.  I can still perform the actions however my selection is not highlighted and I can't be sure that I have selected the correct information until I do a paste in the same, or another, worksheet. I have Excel 2016 in Office 365 on a machine running Windows 10.
2017-02-28T16:18:43+00:00
I have an update on this error dialog: “There's a problem with the clipboard, but you can still paste your content within this workbook."
When Excel shows this dialog after a copy (CTRL+C) action, it means that another app has a lock on the system clipboard.  In this situation you can still paste within Excel.  However you cannot paste to another app like Word or Outlook which uses the clipboard.
Last year we made some improvements to Office365 users so that this error message only shows once per Excel instance.  This is based on customer feedback
  • the design change prevents it popping up multiple successive times when the clipboard is locked.  We have also considered never showing the error dialog, but there was user feedback that this message is informative and helpful in some cases.
We hope this helps shed some light on this error message.  For any design suggestions or new ideas on improving the Excel copy-paste experience, please post to Excel UserVoice.
202 additional answers
    2017-03-10T22:48:49+00:00
    You stated that the office repair utility fixed your issue, but many people have said it didn't help.  Did you have another solution besides run the repair utility?
    2017-03-10T23:15:47+00:00
    No, Running the repair utility did it for me.  Don't know what else might work for others.
    2017-03-15T20:34:47+00:00
    I am now having this problem. It's odd, because Excel has been working fine for me until now, without any problems.
    I have also tried the solutions suggested in this thread (including a reinstall) and the problem remains. I do however still have Office 2010 installed on my PC and using Excel 2010 works fine, without this error. As soon as I fire up the new version however, I get the message (and to make things worse, the spreadsheet 'freezes').
    So, it's clearly not another App 'locking' the clipboard, else cut/copy paste wouldn't work in the 2010 version. I'll stick to the old version for now, but it would be nice to know what's happened.
    2017-03-27T10:05:01+00:00
    I have had a problem with this issue as well. I believe it has a lot to do with your computer's Virtual Memory. If you enter "Change Virtual Memory,[operating system]" into a Google search you can find the instructions on how to increase your VM. For example; My VM was allocated 1125 (MB)/ I change the minimum to 1125 and the maximum to 4438 (MB). Note: when  you have the VM dialog box open the suggested maximum is shown at the bottom of the dialog box. Give this a try!
