"there's a problem with the clipboard, but you can still paste this content within this workbook"
2016-11-17T14:55:36+00:00
Perhaps someone could direct to a discussion where this has been tackled, but I keep getting this error "there's a problem with the clipboard, but you can still past this content within this workbook " with simple cut/copy and paste actions in Excel.  The error box pops up and an alert sounds (which is super annoying) after every paste.  I can still perform the actions however my selection is not highlighted and I can't be sure that I have selected the correct information until I do a paste in the same, or another, worksheet. I have Excel 2016 in Office 365 on a machine running Windows 10.
2017-02-28T16:18:43+00:00
I have an update on this error dialog: “There's a problem with the clipboard, but you can still paste your content within this workbook."
When Excel shows this dialog after a copy (CTRL+C) action, it means that another app has a lock on the system clipboard.  In this situation you can still paste within Excel.  However you cannot paste to another app like Word or Outlook which uses the clipboard.
Last year we made some improvements to Office365 users so that this error message only shows once per Excel instance.  This is based on customer feedback
  • the design change prevents it popping up multiple successive times when the clipboard is locked.  We have also considered never showing the error dialog, but there was user feedback that this message is informative and helpful in some cases.
We hope this helps shed some light on this error message.  For any design suggestions or new ideas on improving the Excel copy-paste experience, please post to Excel UserVoice.
202 additional answers
    2016-12-26T23:35:03+00:00
    Actually, I solved this problem some time ago by using the Office Repair utility.  Thanks.
    2017-02-17T16:31:36+00:00
    I have responded on a different thread: https://answers.microsoft.com/en-us/msoffice/forum/msoffice\_excel-mso\_win10/clipboard-problem-in-excel-2016/224b2a59-8a0c-4897-baba-a481dd06e085
    Here is some info we have gathered. Engineering is investigating the issue.
    I have another update on this error: “There's a problem with the clipboard, but you can still paste your content within this workbook."
    Excel engineering can repro the problem and I was able to repro it myself. What is happening, is that some other app has a lock on the clipboard. Excel doesn't need the clipboard when doing a copy/paste inside Excel but it does need the clipboard if you paste outside of Excel, and the clipboard is unavailable. What you see if that if another app has a lock on the clipboard, you get the above alert and then the paste occurs inside Excel. If you try to paste outside of Excel, such as into Word or WordPad, nothing happens...nothing gets pasted.
    The same thing happens in Word and WordPad when another app has a lock on the clipboard, except that they don't raise the alert - they just silently fail - i.e. nothing happens when you paste.
    The alert is an attempt to tell the user that pasting within Excel will work, but pasting outside of Excel won't work. Last July, we made some changes to the alert. It used to say "We couldn't free up space on the Clipboard.  Another program might be using it right now." In July, we changed the message to “There's a problem with the clipboard, but you can still paste your content within this workbook." and it was changed to only come up once per Excel instance.
    One option is to silently fail like Word, PPT, WordPad, etc. I welcome your thoughts on silently failing. I will pass them on to the Excel engineering team.
    -Mike
    2017-02-17T18:57:36+00:00
    This problem actually went away for me quite some time ago after I used the Office repair utility.
    2017-03-08T20:45:11+00:00
    I used the repair utility but I still have the problem.  It happens nearly every time I move cells or copy and paste.  Not once per session.  How do I fix this?  Very frustrating.
