"there's a problem with the clipboard, but you can still paste this content within this workbook"
2016-11-17T14:55:36+00:00
Perhaps someone could direct to a discussion where this has been tackled, but I keep getting this error "there's a problem with the clipboard, but you can still past this content within this workbook " with simple cut/copy and paste actions in Excel.  The error box pops up and an alert sounds (which is super annoying) after every paste.  I can still perform the actions however my selection is not highlighted and I can't be sure that I have selected the correct information until I do a paste in the same, or another, worksheet. I have Excel 2016 in Office 365 on a machine running Windows 10.
2017-02-28T16:18:43+00:00
I have an update on this error dialog: “There's a problem with the clipboard, but you can still paste your content within this workbook."
When Excel shows this dialog after a copy (CTRL+C) action, it means that another app has a lock on the system clipboard.  In this situation you can still paste within Excel.  However you cannot paste to another app like Word or Outlook which uses the clipboard.
Last year we made some improvements to Office365 users so that this error message only shows once per Excel instance.  This is based on customer feedback
  • the design change prevents it popping up multiple successive times when the clipboard is locked.  We have also considered never showing the error dialog, but there was user feedback that this message is informative and helpful in some cases.
We hope this helps shed some light on this error message.  For any design suggestions or new ideas on improving the Excel copy-paste experience, please post to Excel UserVoice.
202 additional answers
    2018-07-22T20:16:46+00:00
    I thank you for trying, even if it does not help everyone. That is more than we get from Microsoft, much of the time.
    In my case, I have found that the bug seems to be that Excel itself has locked the Clipboard. Clearing the selection before selecting another cell or group of cells allows the copy to work. This may be due to a missing unlock, out-of-order operations, or a race condition in which one thread attempts to copy before a background thread has release the Clipboard lock.
    Again, I ask Microsoft where to send a bill for my QA services, ;)
    2018-07-30T16:00:22+00:00
    In regards to the reasoning of the pop-up...  my question would be...
    HOW DO I FIND OUT WHAT OTHER PROGRAM HAS A LOCK ON THE CLIPBOARD SO THAT I CAN DISABLE THE LOCK?
    This is one of the most frustrating experiences I have EVER had with Excel.  You should easily provide the end user with the option to HIDE the notification!
    2018-07-31T00:34:09+00:00
    From the way it behaves, the "other" program that has the clipboard locked is Excel itself.
    If you copy something and then immediately try to copy something else, the error occurs.
    Click somewhere else and press "esc" to clear the clipboard lock, and then you should be able to copy again.
    2018-08-01T15:53:31+00:00
    Last year we made some improvements to Office365 users so that this error message only shows once per Excel instance.  This is based on customer feedback - the design change prevents it popping up multiple successive times when the clipboard is locked.  We have also considered never showing the error dialog, but there was user feedback that this message is informative and helpful in some cases.
    What special people did you get "user feedback that this message is informative and helpful in some cases"?? My guess is NO ONE. How is this message Remotely helpful when it fails to provide ANY insight as to what "problem" it is detecting with the clipboard. HOW on Gods green earth is this USEFUL???
