"there's a problem with the clipboard, but you can still paste this content within this workbook"
2016-11-17T14:55:36+00:00
Perhaps someone could direct to a discussion where this has been tackled, but I keep getting this error "there's a problem with the clipboard, but you can still past this content within this workbook " with simple cut/copy and paste actions in Excel.  The error box pops up and an alert sounds (which is super annoying) after every paste.  I can still perform the actions however my selection is not highlighted and I can't be sure that I have selected the correct information until I do a paste in the same, or another, worksheet. I have Excel 2016 in Office 365 on a machine running Windows 10.
2017-02-28T16:18:43+00:00
I have an update on this error dialog: “There's a problem with the clipboard, but you can still paste your content within this workbook."
When Excel shows this dialog after a copy (CTRL+C) action, it means that another app has a lock on the system clipboard.  In this situation you can still paste within Excel.  However you cannot paste to another app like Word or Outlook which uses the clipboard.
Last year we made some improvements to Office365 users so that this error message only shows once per Excel instance.  This is based on customer feedback
  • the design change prevents it popping up multiple successive times when the clipboard is locked.  We have also considered never showing the error dialog, but there was user feedback that this message is informative and helpful in some cases.
We hope this helps shed some light on this error message.  For any design suggestions or new ideas on improving the Excel copy-paste experience, please post to Excel UserVoice.
202 additional answers
    2018-06-02T21:27:58+00:00
    It's June 2, 2018 and I am having this problem Office 365 and a brand new i7 with Windows 10.  It occurs each time I need to paste. So issue is not resolved.
    2018-06-12T16:29:25+00:00
    I continue to get this message. Not just "once per excel instance".
    and I can easily paste to outlook, so not really sure what the deal is here.
    2018-06-12T21:51:13+00:00
    To All,
    Here is a mitigation that was noted by someone else some time ago and it did not solve my problem but it did limit it to only the first time I opened an Excel file and performed a Copy Paste sequence. Additionally, if you keep any Excel file open for the entire day/work period the stupid notice is ever displayed again for that time frame. I've listed the menu path to find the option below:
    File Tab
    Options
    General
    Uncheck: "Enable Live Preview"
    Hope that helps.
    2018-06-12T23:14:58+00:00
    Did this months ago & it did/has not helped.
