"there's a problem with the clipboard, but you can still paste this content within this workbook"
2016-11-17T14:55:36+00:00
Perhaps someone could direct to a discussion where this has been tackled, but I keep getting this error "there's a problem with the clipboard, but you can still past this content within this workbook " with simple cut/copy and paste actions in Excel.  The error box pops up and an alert sounds (which is super annoying) after every paste.  I can still perform the actions however my selection is not highlighted and I can't be sure that I have selected the correct information until I do a paste in the same, or another, worksheet. I have Excel 2016 in Office 365 on a machine running Windows 10.
2017-02-28T16:18:43+00:00
I have an update on this error dialog: “There's a problem with the clipboard, but you can still paste your content within this workbook."
When Excel shows this dialog after a copy (CTRL+C) action, it means that another app has a lock on the system clipboard.  In this situation you can still paste within Excel.  However you cannot paste to another app like Word or Outlook which uses the clipboard.
Last year we made some improvements to Office365 users so that this error message only shows once per Excel instance.  This is based on customer feedback
  • the design change prevents it popping up multiple successive times when the clipboard is locked.  We have also considered never showing the error dialog, but there was user feedback that this message is informative and helpful in some cases.
We hope this helps shed some light on this error message.  For any design suggestions or new ideas on improving the Excel copy-paste experience, please post to Excel UserVoice.
202 additional answers
    2018-02-02T19:45:21+00:00
    Never mind - just read your PS (again).  Office build 7192.5000
    Chris,
    That roleback is only for Click-to-Run (365 subscription) versions of Office (365 Office 2013 and 2016).  If you are having the same issue with Office 2010, you may be experiencing a different issue than the other folks in this thread.
    Here is the full article about reverting to a previous version of Click-to-Run.
    https://support.microsoft.com/en-us/help/2770432/how-to-revert-to-an-earlier-version-of-office-2013-or-office-2016-clic
    Chris,
    I would try a reinstall of Office.  I do notice that you have the 64bit version installed.  I would recommend installing the 32bit version if you are able to.  Many applications that integrate into Office will not work with the 64bit version of Office.  Office is not an app that you match to your OS.  Microsoft actually recommends against installing a 64bit version because of these incompatibilities with other software.
    2018-02-02T22:24:40+00:00
    Randy,
    I'm OK with what I got.  Interesting hearing about 64 vs 32 bit versions.  Verrrrrrrrrrrry interesting.
    A reinstall / activation of 2010 gets kinda funky.  But I did it anyway - same, same.
    Interesting this only showed up last September or October.  No issues in 7 years.  That tells me something changed in the re-programming of the clipboard in Win 10 - especially if 365 user's are having the same issue.  Only happens when dragging data from one cell to another.  Copy/paste works fine.   So does striking the enter key when it asks, "Was This Information Helpful?"  Yea right.  Sure it is.
    I appreciate your responses.  Thanks.  I just ain't gonna worry about it.  I'll survive.  :-)  Take care.
    Chris
    2018-02-09T18:21:15+00:00
    Well, should not you mention why the clipboard is locked. and how to unlock it
    2018-02-09T19:46:44+00:00
    I would if I could.  Maybe uninstall KB(whatever).  Who knows.  Sorry.  MS - are you reading these?
