"there's a problem with the clipboard, but you can still paste this content within this workbook"
2016-11-17T14:55:36+00:00
Perhaps someone could direct to a discussion where this has been tackled, but I keep getting this error "there's a problem with the clipboard, but you can still past this content within this workbook " with simple cut/copy and paste actions in Excel.  The error box pops up and an alert sounds (which is super annoying) after every paste.  I can still perform the actions however my selection is not highlighted and I can't be sure that I have selected the correct information until I do a paste in the same, or another, worksheet. I have Excel 2016 in Office 365 on a machine running Windows 10.
2017-02-28T16:18:43+00:00
I have an update on this error dialog: “There's a problem with the clipboard, but you can still paste your content within this workbook."
When Excel shows this dialog after a copy (CTRL+C) action, it means that another app has a lock on the system clipboard.  In this situation you can still paste within Excel.  However you cannot paste to another app like Word or Outlook which uses the clipboard.
Last year we made some improvements to Office365 users so that this error message only shows once per Excel instance.  This is based on customer feedback
  • the design change prevents it popping up multiple successive times when the clipboard is locked.  We have also considered never showing the error dialog, but there was user feedback that this message is informative and helpful in some cases.
We hope this helps shed some light on this error message.  For any design suggestions or new ideas on improving the Excel copy-paste experience, please post to Excel UserVoice.
202 additional answers
    2018-01-31T19:25:42+00:00
    Hi - thanks for the input.   I do have administration privileges on the local drive.  I think you're on something though - the way the clipboard is managed (address pointers?).  Who knows.  Until then, enter key works OK - annoying though.
    2018-01-31T22:01:15+00:00
    "When Excel shows this dialog after a copy (CTRL+C) action, it means that another app has a lock on the system clipboard.  In this situation you can still paste within Excel.  However you cannot paste to another app like Word or Outlook which uses the clipboard."
    "Last year we made some improvements to Office365 users so that this error message only shows once per Excel instance."
    In response to the first quote I have three questions:
    1. How do you find out what application is responsible for the system clipboard being locked?
    2. How do you 'unlock' the system clipboard?
    3. How do you prevent this from happening?
    In response to the second quote I just have a comment: as an Office365 user, I have not found this to be true. I get the error message every time I copy & paste or drag values from one cell to another (in a single instance of Excel, which is also the only Office application I have open). Very annoying.
    2018-02-01T01:18:00+00:00
    So, who's locking the clipboard?  Not me.  :-)
    Background something-or-other?
    2018-02-01T06:14:26+00:00
    This is annoying. I keep getting the message error message addressed above even after disabling Live Preview. How can I stop it?
