"there's a problem with the clipboard, but you can still paste this content within this workbook"
2016-11-17T14:55:36+00:00
Perhaps someone could direct to a discussion where this has been tackled, but I keep getting this error "there's a problem with the clipboard, but you can still past this content within this workbook " with simple cut/copy and paste actions in Excel.  The error box pops up and an alert sounds (which is super annoying) after every paste.  I can still perform the actions however my selection is not highlighted and I can't be sure that I have selected the correct information until I do a paste in the same, or another, worksheet. I have Excel 2016 in Office 365 on a machine running Windows 10.
2017-02-28T16:18:43+00:00
I have an update on this error dialog: “There's a problem with the clipboard, but you can still paste your content within this workbook."
When Excel shows this dialog after a copy (CTRL+C) action, it means that another app has a lock on the system clipboard.  In this situation you can still paste within Excel.  However you cannot paste to another app like Word or Outlook which uses the clipboard.
Last year we made some improvements to Office365 users so that this error message only shows once per Excel instance.  This is based on customer feedback
  • the design change prevents it popping up multiple successive times when the clipboard is locked.  We have also considered never showing the error dialog, but there was user feedback that this message is informative and helpful in some cases.
We hope this helps shed some light on this error message.  For any design suggestions or new ideas on improving the Excel copy-paste experience, please post to Excel UserVoice.
202 additional answers
    2016-11-23T21:55:40+00:00
    Doffyourcap, this happens with all spreadsheets.  Including newly created sheets.
    Other spreadsheets I open are set to enable editing with the same result.
    Thanks for responding.
    Pedro
    2016-11-27T12:20:19+00:00
    Hi Pedro,
    To isolate the issue, we would like to ask for the following information:
    • Does the same error message appear when you are using other Office applications (e.g. Word, Outlook, etc.)?
    • Have you tried running Excel in Safe Mode to see if the issue will persist?
    Regards.
    2016-11-27T13:02:17+00:00
    Negative - I followed the link for the 'repair' against my better judgement knowing full well that office was installed on a freshly installed Windows 10 Professional image. The repair hung - I had to reboot, and reinstall from MS.
    And, voila - after spending several hours with the 'fix' - open Excel and - SAME clipboard error. I mean yikes - I had no idea how much I cut and paste in Excel until this issue appeared. And, for the most part, the cut and pastes are legit!~
    2016-11-27T13:24:40+00:00
    Hi JohnRod,
    This problem doesn't exist in other Office applications.
    I have tried running Excel in Safe Mode and the problem persists.
    Cheers
    Pedro
