"there's a problem with the clipboard, but you can still paste this content within this workbook"
2016-11-17T14:55:36+00:00
Perhaps someone could direct to a discussion where this has been tackled, but I keep getting this error "there's a problem with the clipboard, but you can still past this content within this workbook " with simple cut/copy and paste actions in Excel.  The error box pops up and an alert sounds (which is super annoying) after every paste.  I can still perform the actions however my selection is not highlighted and I can't be sure that I have selected the correct information until I do a paste in the same, or another, worksheet. I have Excel 2016 in Office 365 on a machine running Windows 10.
2017-02-28T16:18:43+00:00
I have an update on this error dialog: “There's a problem with the clipboard, but you can still paste your content within this workbook."
When Excel shows this dialog after a copy (CTRL+C) action, it means that another app has a lock on the system clipboard.  In this situation you can still paste within Excel.  However you cannot paste to another app like Word or Outlook which uses the clipboard.
Last year we made some improvements to Office365 users so that this error message only shows once per Excel instance.  This is based on customer feedback
  • the design change prevents it popping up multiple successive times when the clipboard is locked.  We have also considered never showing the error dialog, but there was user feedback that this message is informative and helpful in some cases.
We hope this helps shed some light on this error message.  For any design suggestions or new ideas on improving the Excel copy-paste experience, please post to Excel UserVoice.
202 additional answers
    2017-09-29T13:27:16+00:00
    That doesn't work. Un-checking "Enable Live Preview" does not prevent the message from appearing nor does it eliminate the annoying message of "there's a problem with the clipboard, but you can still paste this content within this workbook"
    2017-10-27T14:21:46+00:00
    You people are great at sending updates.   Stop using your user base to try to fix this problem!   It's obvious there is a problem.   Find a solution and send an update that will fix it!!!  Just make sure it doesn't screw up anything else!!!
    2017-10-27T15:48:12+00:00
    I am still getting this error message in Excel v. 1709 (Build 8528.2139).  It happens when Enable Live Preview is off.  It happens every time (not just once) when I drag and drop (but not cut and paste or CTRL.C CTRL.V).  It only occurs when Outlook is open. I run the Configuration Analyser regularly.
    2017-10-27T20:15:49+00:00
    For some unknown reason, this issue has been resolved for several months now.  Could Microsoft have finally fixed it?  Unsure, but none of the fixes I tried on my own worked.  Suddenly, it's fixed.  maybe temporary, but I'll take it!  Such an annoying problem!
