OneNote making my text invisible!
2017-03-08T20:19:19+00:00
I imagine this is some sort of bug...
OneNote in Office 365 on Windows 10
I use OneNote for a lot of notes, including one section that is password protected. All of a sudden a few days ago, it has this very annoying glitch where the text I type is invisible.
It basically allows me to type / click check boxes, etc., but it is all invisible. As in, it creates space for the words but there is nothing there. I mostly have been using the password protected section, so I notice it there. If I close OneNote and open it back up, the previously invisible words then show up. Sometimes it lets me type regularly again, or sometimes it just makes any new text I type invisible also.
If I press backspace, for example, the cursor moves backwards but the deleted words are still visible (until I close the program, for example).
If I switch to a non-password protected section the words are usually invisible while typing also- but if I keep typing gibberish then after a few seconds, this seems to reset and do the same thing as closing / reopening the program.
Any ideas? This is quite annoying!
Thanks!
2017-03-10T02:24:31+00:00
This issue is also occurring for me. I will type text and the cursor will move as if it is typing but the text does not appear. A short-term solution I have found is that switching to another section and then switching back to the "trouble" section then displays the text when typing.
I have tried both Quick and Full Repair.
The version is Office 365 Home Edition OneNote 2016 desktop app on Windows 10.
Help appreciated!
Jeff
67 additional answers
    2017-05-19T19:25:38+00:00
    This is happening to me as well.  It could be due to a video driver update.  I'm running
    • Multiple 4K monitors
    • On an NVidia card
    Is the latter a common vein?
    Thank you,
    Josh Usovsky
    I thought it may be a video card issue or multiple monitor support issue, but I just switched machines completely (Lenovo ThinkPad laptop to custom built desktop) and I'm having the same exact issue. The two machines have 100% different hardware. Only things that are the same:
    • Using Windows 10
    • Using desktop app of OneNote 2016
    I can repro this issue so consistently now that I would have no problem getting a screen capture. It happens every time I use OneNote and is extremely annoying. The workaround to switch tabs does work temporarily, but if I switch focus to another program then back to OneNote my text is disappearing again with a vengeance. Very disappointed Microsoft hasn't seriously addressed this yet.
    2017-05-20T12:41:19+00:00
    No, I get it with Intel HD graphics and internal display only.
    2017-05-23T19:28:08+00:00
    This problem is haunting us for month now! I experience this problem on all my systems. Even a new notebook computer I bought on the 30th of April.
    OneNote is my most important productivity tool and it was a wonderful tool at that -- I want it back!
    Is anybody working on this problem?!
    2017-06-02T16:58:46+00:00
    I want to let everyone know that I updated my machine to Windows 10 Pro "Creator's Update" v 1703 OS 15063.332, and the problem with invisible text persists in Microsoft OneNote (v 1704, build 8067.2115 click-to-run.)
    Problem still not fixed on any of my machines, running various versions of Windows.  This is crazy.  How is this not happening to all users?
