OneNote making my text invisible!
2017-03-08T20:19:19+00:00
I imagine this is some sort of bug...
OneNote in Office 365 on Windows 10
I use OneNote for a lot of notes, including one section that is password protected. All of a sudden a few days ago, it has this very annoying glitch where the text I type is invisible.
It basically allows me to type / click check boxes, etc., but it is all invisible. As in, it creates space for the words but there is nothing there. I mostly have been using the password protected section, so I notice it there. If I close OneNote and open it back up, the previously invisible words then show up. Sometimes it lets me type regularly again, or sometimes it just makes any new text I type invisible also.
If I press backspace, for example, the cursor moves backwards but the deleted words are still visible (until I close the program, for example).
If I switch to a non-password protected section the words are usually invisible while typing also- but if I keep typing gibberish then after a few seconds, this seems to reset and do the same thing as closing / reopening the program.
Any ideas? This is quite annoying!
Thanks!
2017-03-10T02:24:31+00:00
This issue is also occurring for me. I will type text and the cursor will move as if it is typing but the text does not appear. A short-term solution I have found is that switching to another section and then switching back to the "trouble" section then displays the text when typing.
I have tried both Quick and Full Repair.
The version is Office 365 Home Edition OneNote 2016 desktop app on Windows 10.
Help appreciated!
Jeff
67 additional answers
    2017-03-09T22:20:54+00:00
    Thanks for the information. Since you are using the desktop version, you want to perform the steps on how to repair an Office application.
    If you are still having concerns, feel free to reply on this thread.
    2017-03-09T01:19:15+00:00
    This problem occurs on the desktop version. I don't normally use the browser version on my PC. I have the app on my PC and on my android phone, but I mostly use it on the PC and that is where I am having problems. Nothing noticeably different happened before this.
    I'm not really sure what troubleshooting to try. Should I try uninstalling and reinstalling the desktop app?
    Thanks.
    2017-03-09T00:22:09+00:00
    We would like to know more about the concern you are experiencing with OneNote. For us to have a better view of this one, kindly answer the following questions:
    • Which browser are you using to access OneNote?
    • Were there any changes with your browser or computer before this concern started happening?
    • Do you have a desktop app of OneNote installed on your computer? If so, do you encounter the same concern?
    • Have you performed any troubleshooting steps?
