Text in Navigation Pane turns white
2017-01-25T05:16:11+00:00
In Word for Mac 2016, I am getting a weird issue where, after clicking on a heading in Navigation Pane, the text there turns white.  This causes it to blend with the background and to all but disappear.  The screen shot attached shows what I am talking about.  This does not always happen when clicking a heading, but it happens sporadically - and often.  How to fix?  (BTW, this does not happen on my Windows 10 machine)
2017-07-21T17:24:48+00:00
Be sure to send feedback to Microsoft whenever you encounter this behavior. Click the Smile button in Word to get your message to Microsoft. This forum's primary audience is other Word users.
As Jim says, this forum is primarily used and supported by users. MS developers rarely pay attention to it.
The feedback option is in the File menu > Feedback command.
But to report problems I think you should use the "Send a Frown" button or the "Send A Suggestion" button.
Personally, I prefer the suggestion because the "frown" is a black hole. No feedback to you.  The Suggestion takes you to the UserVoice forum. You can copy the link it creates for your "suggstion" so that you canreturn to it and to share with other people with the same problem so that they can comment on your submission and vote for it. That way more of the information about the problem is in one place.
43 additional answers
    2017-03-02T02:13:08+00:00
    Hi All,
    We have reported the issue to our related team. If there is any update, I will post back to let you know.
    Ran
    2017-03-02T07:22:27+00:00
    I'm afraid I don't currently have the time to set up a new Office 365 account.
    You weren't being asked to setup a new OFFICE account.
    The request was for you to create a new use account / profile on the Mac. Sometimes "corruption" of the Mac user profile has caused problems with Office applications. So a general troubleshooting process on the Mac is to create a new account and see if the problem goes away.
    2017-03-29T13:38:37+00:00
    I have been experiencing the same issue.
    Word version:
    Mac version:
    As described by the others here, the problem happens sporadically and in numerous (if not all) files. In my case, it happens quite often, but I am working with quite large files which seem to exacerbate a number of issues.
    I mostly notice the problem when I'm using split view and am going from one word file to the other. But there is no regularity in this (sometimes the file I am deselecting has the issue, sometimes the file I am selecting has the issue; sometimes nothing happens). It has also happened when I was not in split view, so it is definitely not restricted to split view.
    I also have not found any regularity in what to do to make the text turn black again. Clicking on it does not help.
    2017-03-30T02:08:47+00:00
    Hi Liisa,
    Our related team is still investigating on this issue. If I get any feedback from them, I will update here in the thread. Thanks for your patience.
    Regards,
    Ran
