Track Changes in Word 2016 - deletions not showing
2016-04-25T11:17:05+00:00
Hi all,
I am using Word 2016 and am having problems with track changes. I have it set to show All Markup and under the show markup I have insertions and deletions ticked; however, when I delete something in the Word document, it is not showing as strike though and as such I cannot see that it has been deleted. If I accept the changes, the deleted item will disappear, so it is taking them on board.
Any suggestions? - I am soon going to reinstall an earlier version if I can't solve this as it is completely unworkable.
Stefan Blom 353.6K Reputation points MVP Volunteer Moderator
2016-04-25T13:13:50+00:00
In the Advanced Track Changes Options dialog box, make sure that "Deletions" is set to "Strikethrough" (and not to "Hidden" or "(none)").
To display the dialog box, click the dialog launcher in the Tracking group on the Review tab; in the Track Changes Options dialog box, click Advanced Options.
2017-05-18T16:21:27+00:00
Try setting the Reviewing Pane to Off:
Hope this helps,
HJ
2017-05-18T17:03:26+00:00
Try the following (as illustrated in the figure below) -- on the "Review" tab of the ribbon, in the "Tracking" section, choose "All Markup" from the dropdown list, then open the "Options" dialog and choose to show "Revisions" in the box labelled "Balloons in All Markup view show".  You might also need or want to set the "Reviewing Pane" to "Off" in the box immediately below it.
I hope this helps.
HJ
2017-09-20T09:07:29+00:00
In the Advanced Track Changes Options dialog box, choose how you want deletions to be shown (as strikethrough, for example). See screen shot below. Make any other changes that you want. When you are done, click OK to confirm the settings.
Then click Review | Show Markup | Ballons | Show Only Comments and Formatting in Balloons.
39 additional answers
    2017-04-25T16:43:18+00:00
    LucyMKf66,
    I had the same issue. I would check the boxes and then the changes did not take effect and I did not see my changes contemporaneously. Might have been a change in the last update.
    I had to go to the review menu and make the changes noted in this article:
    https://support.office.com/en-us/article/Track-changes-in-Word-197ba630-0f5f-4a8e-9a77-3712475e806a
    After I made the changes in the menubar, Track Changes worked as before.
    Good luck.
    z_owner
