How to insert a picture in header or footer in Excel 2016?
2015-07-16T20:52:10+00:00
I'm currently working on a spreadsheet, and I need three pictures in the header. However, I can't find how to do this in Excel 2016. Did Microsoft remove the option? Does anybody know how to do this?
It's funny because I opened a previous version created in Excel 2011, and it shows the picture and then Excel crashes.
Thank you in advance for your answers
William
131 additional answers
    2016-10-28T14:35:01+00:00
    Having the very same problem, extremely annoying since the issue been known since last year!!!
    Workaround: insert "&[Picture]", browse for a picture and thats it. Picture is however static, so you need to make sure it has the right size before insterted.
    Rgrds,
    /Kamahura
  2. Jim G 134K Reputation points MVP
    2016-10-28T16:50:36+00:00
    I tried your suggestion but nothing happened. Can you provide step-by-step instructions?
    2016-10-29T03:10:54+00:00
    I to have attempted to try your "Workaround" with no success. Where are you putting "&[Picture]"? If placed in the header you are not asked to browse for a picture and the result displays as "". In the header the menu Insert > Picture is greyed out so no picture can be inserted and it is impossible to drag and drop into the header. Can you provide a bit more info as Jim suggests.
    2016-11-01T12:07:20+00:00
    Hi James,
    I was wondering if you guys are going to fix the issue, since a year almost passed with no solution yet.
    Ugo
