How to insert a picture in header or footer in Excel 2016?
2015-07-16T20:52:10+00:00
I'm currently working on a spreadsheet, and I need three pictures in the header. However, I can't find how to do this in Excel 2016. Did Microsoft remove the option? Does anybody know how to do this?
It's funny because I opened a previous version created in Excel 2011, and it shows the picture and then Excel crashes.
Thank you in advance for your answers
William
131 additional answers
    2016-04-07T08:31:17+00:00
    Unfortunately, this feature still isn't available in the latest Insider Preview Excel release (15.21).  There are no options to insert a picture from the Header menu, and copying / pasting an image directly into a header field also failed (no result), although the same image was successfully copied into a random cell.
    I've gone back to Office 2011 for Mac on my work computer but keep checking each new release of Office 2016 to see what bug fixes or features have been made available.  Surprisingly, very few useful features have been added in the past two releases, and under the Help menu there is no longer an option to Check for Updates!
    It's a shame there hasn't been any real progress recently, other than the (partially) customisable Quick Access Toolbar.
    2016-04-23T14:10:34+00:00
    Hope this update is sooner rather than later :)
    2016-04-24T03:35:57+00:00
    Geoffrey,
    In my version of Excel 2016 Version 15.21.1 the "Check for Updates" is still there:
  4. Jim G 134K Reputation points MVP
    2016-04-24T15:58:53+00:00
    Microsoft began a review process about this feature August, 2015. The review is still underway. Once the review has been completed Microsoft will make a decision as to whether or not they will add this request to the list of features that will be eventually worked on. Obviously, this is getting a very thorough review. It's not easy to decide whether or not to fix something, you know.
    Enable pictures or photos to be inserted into the header of an excel sheet
