Styles in word 2016 not working properly
2015-12-28T04:19:27+00:00
Dear All,
I need help from you.
I cannot use Styles in Word 2016 properly, the problem is:
I want to use "Body Text", "Heading", "List Bullet", "List Number". When I click on "Body Text" but it jump to "TOC", it is not exactly "Body Text".
When I click on "Heading 1" it jump to "Heading 2" and next click jump to "Heading 3" and so on.
In previous version I always use these Styles but not faced these Problem.
After I change to this version I facing with this problem.
I use Microsoft Office Home and Business 2016.
2016-01-14T19:53:46+00:00
Hi everyone!
The Office 2016 December update introduced an issue where the wrong style would get applied if you tried to select a style in the Styles pane.
That issue has been fixed in update 6366.2056, which is rolling out now to Office 365 consumer/small business subscribers. If you don't see the update yet, follow these steps:
  1. Open any Office application and choose File > Account. (If you're using Outlook, choose File > Office Account.)
  2. Under Product Information, choose Update Options > Update Now.
If you're still experiencing issues in 6366.2056, please let us know (best to start a new thread).
Thanks for your patience.
103 additional answers
    2016-01-06T21:21:28+00:00
    Yes, I do have an NVIDIA video card.
    Windows 10, version 1511 - ASUS ACPI x64 Based PC Laptop
    NVIDIA GeForce 940M -  v10.18.13.5354 - Intel(R) HD Graphics 5500
    The major Windows 10 update that affected Word was on or about December 10, 2015
    2016-01-07T15:11:04+00:00
    FYI, neither one of these suggested fixes worked for me.
    2016-01-07T15:12:27+00:00
    Thanks for so much for posting this! None of the other suggested solutions worked for me, and I'd pretty much be dead in the water without this workaround.
    2016-01-07T18:57:20+00:00
    Okay, I'm seeing a common thread. One other person had an NVidia card as well. Mine's only a GeForce 465 but both from NVidia. I talked to NVidia and they gave me a back-version driver.  This did not fix the problem but I'm now trying another fix (suggested by an MVP)--Disable Hardware Accelleration. This looks promising.
