Styles in word 2016 not working properly
2015-12-28T04:19:27+00:00
Dear All,
I need help from you.
I cannot use Styles in Word 2016 properly, the problem is:
I want to use "Body Text", "Heading", "List Bullet", "List Number". When I click on "Body Text" but it jump to "TOC", it is not exactly "Body Text".
When I click on "Heading 1" it jump to "Heading 2" and next click jump to "Heading 3" and so on.
In previous version I always use these Styles but not faced these Problem.
After I change to this version I facing with this problem.
I use Microsoft Office Home and Business 2016.
2016-01-14T19:53:46+00:00
Hi everyone!
The Office 2016 December update introduced an issue where the wrong style would get applied if you tried to select a style in the Styles pane.
That issue has been fixed in update 6366.2056, which is rolling out now to Office 365 consumer/small business subscribers. If you don't see the update yet, follow these steps:
  1. Open any Office application and choose File > Account. (If you're using Outlook, choose File > Office Account.)
  2. Under Product Information, choose Update Options > Update Now.
If you're still experiencing issues in 6366.2056, please let us know (best to start a new thread).
Thanks for your patience.
103 additional answers
  1. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2016-01-24T22:31:26+00:00
    It is NOT a problem that I have experienced or that the Product Team have been able to reproduce.  The very least that you could do, if you are interested in helping overcome the problem is to do as requested and send a copy of the template and of a document that exhibits the problem.
    If you do not wish to do that, all that I can suggest is that you revert to 2013.
    https://support.office.com/en-us/article/How-do-I-reinstall-Office-2013-after-an-Office-2016-upgrade-a6ca92f4-cbb4-4609-9fdb-f8d3dd6812f3
    2016-01-24T23:03:07+00:00
    Doug, A Post from a Forum Moderator back on Dec 29 and I quote...
    "Anneliese [MSFT] Microsoft EmployeeMicrosoft
    Forum Moderator - Multiple Forums Styles in word 2016 not working properly "Hi John,
    The Word team is aware of this bug and investigating now. In the meantime, can you try one of these potential workarounds and see if either solves your problem? Assuming that the Styles pane isn't docked, try increasing the size of the Styles pane so you see more styles.
    • or- Clear the Show Preview box at the bottom of the floating Styles pane.
    Thanks!"
    DO YOU PEOPLE Cross communicate? Believe me Microsoft Techs are aware of this Styles Wonky problem!
  3. Suzanne S Barnhill 279.2K Reputation points MVP Volunteer Moderator
    2016-01-24T23:08:15+00:00
    We are very much aware of those threads and of the update that has cured most (but, as you note, not all) of the problems. Work on the problem continues, and sample documents exhibiting the problem are helpful in troubleshooting.
    2016-01-24T23:25:24+00:00
    Suzanne, Doug said..."It is NOT a problem that I have experienced or that the Product Team have been able to reproduce."
    Come on! ....if he has Word 2016 .....he would have to experience the Bug ...."Cured most" .....it didn't totally solve the wonky Styles BUG .....This Bug happened when the Dec 10, 2015 Windows major update was pushed out ......
    This has been a major issue for us that have to make part of our living formatting large Word documents .....we shouldn't have to be told ...go back to Office 2013 .....to deal with the problem .....I paid for Office 365/Word 2016 ....I want it to work correctly ......How many Office 365/Word 2016 applications has MS sold? Hundreds of Thousands? at an average of $99.00.....= Millions of dollars........If you had a million dollar Car recall I bet you'd get a quick action .....
    Believe me, money lost on bad products gets attention with most companies ....MS better fix this before it gets out to the National Tech Press .......;-(
