Word 2016 for mac not manage hyperlink when .doc is converted into .pdf
2015-09-24T14:03:23+00:00
I'm using Word 2016 on Mac, but when I save a .pdf file from a .doc document it lost hyperlink.
In details, if I want to create an hyperlink starting to a simple word (ex: industry name) who take me to industry's website, saving .doc as .pdf will lost the hyperlink, but formatted word remain ad an hypertext.
How can I solve this issue?
Thanks.
2016-08-01T09:14:56+00:00
Actually, there is a way to generate PDF files including hyperlinks with Word 2016 for Mac :
1 - Insert hyperlinks in your document,
2 - Go to "Save as...", choose PDF and check the box "Best for electronic distribution and accessibility" instead of "Best for printing",
3 - Save. It will take a while as it uses Microsoft online services but then the generated PDF file includes hyperlinks!
Hope it will be useful to someone.
2016-08-18T13:39:05+00:00
Well, the folks at Microsoft have done some tweaking and adjustments and the feature is now active.
If you don’t have any Right-to-left input method (in Keyboards) or language (in Language & Region) active in the System Preferences, and you use a version of Word >15.23.1, then the options should now be visible when you use the Save As command and select PDF.
The file is processed through an online service and you get a Tagged PDF (with all forms of links active).
Make sure you select: Best for online distribution and accessibility
 Corentin
2017-12-04T18:11:14+00:00
This really did not help. "Best for electronic distribution and accessibility" does not retain the quality of visuals at all. in fact it also converts symbols as junk characters.
Any other more sustainable solutions? Thanks!
Nope… There is no good option in Word.
As you’ve seen, you can 1. generate it through the MS online services, get the metafunctions like links, etc, but loose embedded fonts and the high quality of the artwork. 2. Use the macOS PDF Services which retain fonts and original artwork, but do not add metafunctions like links, etc.
The only option to get both is to open up the document in another app that will offer that (OpenOffice??) with the risk of seeing slight layout differences, or open up the document on Windows where Word can natively generate a full-featured PDF :-\
Corentin
47 additional answers
  1. John Korchok 236.2K Reputation points Volunteer Moderator
    2016-09-02T20:31:56+00:00
    If you use Help>Check for Updates, you should be able to get 15.25, I don't know if that will improve what you're seeing..
    2016-09-06T16:25:28+00:00
    I installed the most recent updates. My version is now 15.25 (160817). I'm not part of any special program.
    Up to two minutes ago I kept getting a message about the online pdf printing service being unavailable. That was temporary though. Now it works as before. That is, the bad spacing/missing fonts issue is still there. Nothing changed.
    Also, for a while word seemed at war with the os. It crashed a number of times while performing extremely simple operations. Thing that had word crash
    • opening existing files.
    • inserting an equation in a document.
    Now things seem to have normalized, but I do not know why or how.
