"Undo" causing problems in Word 365
2015-10-12T22:12:31+00:00
Using Word 365 on a Mac:
Haven't been able to find other people posting about the same issue. I'm having problems with the "undo" feature - while typing a document, Word seems to have picked specific spots to revert to every time I undo a change and then not allowing a redo. As a result, every time I hit command+Z (out of habit as I type), I lose all my work to the last "property update" (as far as I can tell, a formatting edit).
It's hard to explain but basically, undo removes work done up to a certain point, not the last edit or change, and then does not allow me to redo. Has anyone had this problem and how did you fix it?
Jim G 134.1K Reputation points MVP
2017-02-21T17:58:28+00:00
Your Mac is behind on updates. Please install updates then test again to see if the problem remains.
Make sure your Mac has a working internet connection before checking for updates. Install Mac OS X updates followed by Office updates.
Install Mac OS X updates first:
To get Mac OS updates, go to the App store on your dock, and then click the Updates button to reveal available updates.
Then Install Office Updates
To get the update:
  1. Open any Office application:
  2. Make sure your Mac has a working internet connection
  3. Go to the Help menu and choose Check for Updates
  4. Let AutoUpdate check for and install updates
  5. Restart your Mac
John Korchok 236.2K Reputation points Volunteer Moderator
2017-11-13T15:28:10+00:00
It's probably simplest for you to move your documents from the old account to the new one, since you haven't been using this computer for long. Here's a page showing how to do that: Transfer Files Between Two OS X Accounts
It would be great if Microsoft could figure out how completely uninstall Office 2016 for Mac to fix problems. The fact that moving to a new account solves the issue proves that the existing instructions are not complete enough. You can vote for this User Voice idea to request them to do that.
2017-12-15T03:00:15+00:00
Funny enough, after I posted earlier today, my Word updated—in fact, it insisted: it closed out of what I was working on. It does not do that normally. And now it's Version 16.8. Very odd... (I did try experiment with checking the "Join the Office Insider program to get early access to new releases"—which offered new updates).
Also, the Chrome issue is not a Chrome issue per se. Rather copying and pasting from other Word documents will do it. I think the issue has to do with the merging of differing formatting? (Which is the case when pasting from Chrome).
We'll see if the issue persists. It hasn't reoccurred since the update—but I've been lured into a sense of security before on this...
2017-12-09T02:38:31+00:00
If you're really running version 15.4, you are extremely behind in updates. Please use Help>Check for Updates, install the latest version, restart your Mac and try again.
If you simply left off a 0 and are running 15.40, be sure to click on the small smiley-face icon in the upper-right corner of the program window, choose Tell Us What Can Be Better and describe the problem in detail. Submitting sends a bug report directly to the programming team.
2017-03-19T11:31:25+00:00
You were right, updating solved my problem ! Thanks a lot !
47 additional answers
  1. John Korchok 236.2K Reputation points Volunteer Moderator
    2017-11-13T01:14:26+00:00
    When did this start to happen? Was it shortly after upgrading your operating system or your copy of Office 365? Please tell us all the details.
