Excel 2016 (Protected Mode) Crashing When Opening Files From Email
2015-09-29T23:14:57+00:00
Has anyone else encountered this problem?
  • Receive an Excel file in email (both GMail and (desktop) Outlook 2016 (using a live.com account, not a GMail one) have been tested);
  • Double click on it to open it. (Excel 2016 is already open);
  • The file opens in Excel with that irritating little "Oooooh, very dangerous! Could be scary monsters inside!" message which, I'll admit, is potentially useful for files from outside the organisation which is the only reason that I leave it on. Of course, there's no point if it doesn't actually work.
Then one of two things happens. Either
  • You go to click the Enable Editing button and Excel completely hangs on you; or
  • You get the "Excel (Protected Mode) {breathless pause...} Has! Stopped! Working! Pretending to check for a solution that has never once been found in my lifetime, please waste your time waiting" dialog.
There is nothing wrong with the file itself. I have tried with two different files, both have a problem. In both cases if instead of opening them from the Email application I save them to a trusted location I can open them without problem. But opening them directly from either browser or Outlook completely crashes Excel 2016 in a way that it didn't with Excel 2010.
Anyone else?
PS: If anyone from Microsoft responds to this post, looking into this specific question, I'll be more than happy to listen. If instead they copy and paste a script about restarting Windows in Safe Mode I may just need to throw a shoe at something.
2015-11-10T23:39:54+00:00
I just heard back from a displaylink tech support person.  Apparently they are aware of the issue.  He had me do a work around that has fixed the issue for me.
  1. Open a blank excel document.
  2. Go to file
3.  Go to options
  1. Go to advanced
  2. Under Display
  3. Check the box...Disable graphics hardware acceleration.
7.  Click apply.
This has fixed my issue until there is a driver update.
Thanks...Matt
2016-02-24T04:16:51+00:00
Updated to displaylink driver 7.9m5 dated 2/23/2016 and problem was resolved for me.
88 additional answers
    2015-11-08T21:14:09+00:00
    Two computer having the same issue after a windows update.  Office 2016 protected view crashes.  Can't open any attachments...it was working before the update and not after.  I can do a system restore to before the windows update.  I can't avoid the update...it will install itself again and then I have the same problem.  Windows 10 and office 2016.
    FIX THIS MICROSOFT!!!
    2015-11-09T17:27:12+00:00
    I was curious if everyone experiencing this issue has this driver installed on their machine.
    DisplayLink Corp. driver update for DisplayLink Display Adapter (03E0)
    Thank you..
    2015-11-09T18:36:59+00:00
    I don't have the laptop in question to hand to confirm the (03E0) part, but yes, I'm using a DisplayLink adapter/dock.
