Excel 2016 (Protected Mode) Crashing When Opening Files From Email
2015-09-29T23:14:57+00:00
Has anyone else encountered this problem?
  • Receive an Excel file in email (both GMail and (desktop) Outlook 2016 (using a live.com account, not a GMail one) have been tested);
  • Double click on it to open it. (Excel 2016 is already open);
  • The file opens in Excel with that irritating little "Oooooh, very dangerous! Could be scary monsters inside!" message which, I'll admit, is potentially useful for files from outside the organisation which is the only reason that I leave it on. Of course, there's no point if it doesn't actually work.
Then one of two things happens. Either
  • You go to click the Enable Editing button and Excel completely hangs on you; or
  • You get the "Excel (Protected Mode) {breathless pause...} Has! Stopped! Working! Pretending to check for a solution that has never once been found in my lifetime, please waste your time waiting" dialog.
There is nothing wrong with the file itself. I have tried with two different files, both have a problem. In both cases if instead of opening them from the Email application I save them to a trusted location I can open them without problem. But opening them directly from either browser or Outlook completely crashes Excel 2016 in a way that it didn't with Excel 2010.
Anyone else?
PS: If anyone from Microsoft responds to this post, looking into this specific question, I'll be more than happy to listen. If instead they copy and paste a script about restarting Windows in Safe Mode I may just need to throw a shoe at something.
2015-11-10T23:39:54+00:00
I just heard back from a displaylink tech support person.  Apparently they are aware of the issue.  He had me do a work around that has fixed the issue for me.
  1. Open a blank excel document.
  2. Go to file
3.  Go to options
  1. Go to advanced
  2. Under Display
  3. Check the box...Disable graphics hardware acceleration.
7.  Click apply.
This has fixed my issue until there is a driver update.
Thanks...Matt
2016-02-24T04:16:51+00:00
Updated to displaylink driver 7.9m5 dated 2/23/2016 and problem was resolved for me.
88 additional answers
    2015-11-05T01:18:02+00:00
    Adding my name to the list of people affected by this bug.
    -- Nick
    2015-11-05T06:58:31+00:00
    I have the same problem and the workaround is to drag the attachment to a local folder and open that copy. The same problem also occur when opening office documents in network drives. I have to copy them to my local drive and copy them back after editing.
    2015-11-05T07:58:20+00:00
    I am also having the issue of not being able to open from an external network drive or outlook. I have spent most of the last 2 days with Microsoft technical support but they have no answers but are happy for me to pay them more money to look at the problem. Sounds like the error will continue until there is a fix. Thank goodness for this forum because I would be at a loss as I'm not computer literate.
