Word 2016 Cursor movement slow, jumpy, laggy, erratic, stuttering in some documents
2015-07-13T06:29:26+00:00
It is impossible to edit some documents because of VERY slow, jerky, jumpy, laggy, erratic, stuttering cursor movement (horizontal worse than vertical). I have been forced to go back to using Word 2011. I am a professional novelist and cannot practice my trade with Word 2016!! This is very disappointing.
As a novelist I work with large word count simply formatted documents with a file size of less than 1M. I have not experimented to find a cut off point with regard to word count but documents in the 100K word size or more (less than 1M file size) exhibit this slow, jerky, laggy cursor movement problem. Small documents in the 5K word range do not have this problem on any of my notebooks.
It can take 10 seconds or more to move the cursor from the right to left side of the page (or vice-versa). This slow erratic cursor movement is especially troubling when trying to select a few words (highlighting them) for editing. It is very frustrating.
I have experimented and found that brand new documents in 2016 file format exhibit this problem. I have created documents with zero text formatting and they have this problem. I removed all formatting in these test documents by copying and pasting ASCII text into the newly created 2016 format doc from original Word 2011 documents.
I have replicated this same problem on three different macbook computers all with SSD and max ram. None of these computers are running with more than 5% CPU utilization (running nothing else except Word 2016). All of these notebook computers edit the same files just fine using Word 2011.
  • Brand new 2015 macbook 12" retina
  • 2013 Macbook Pro 13" retina
  • 2013 Macbook Air
Track changes is not turned on, nor is any other unusual "feature" or function. This problem occurs in all display modes: draft, layout, etc.
**All these notebooks are running the latest version of Yosemite and all with 100% up to date software.
**This is a fatal mission-critical problem for me which has forced me to revert back to using Word 2011. Again, this is very disappointing.**I have been a Word user for something over 25 years (started on MS/PC DOS).
Similar / same problems here:
http://answers.microsoft.com/en-us/mac/forum/macoffice2016-macword/office-2016-mac-very-laggy/e2656073-6f1b-4535-b78e-ee79e0a4fb4c
http://answers.microsoft.com/en-us/mac/forum/macoffice2016-macword/word-2016-laggy-ui-and-scrolling-issues/9de4aeb7-9058-4fb0-a331-72076fed72b2
http://answers.microsoft.com/en-us/mac/forum/macoffice2016-macword/performance-of-scrolling-in-word-2016-for-mac-is/f04bbc86-5753-4ef5-a2c3-5cfdcb8cb837
2016-12-14T20:46:25+00:00
I confirm quitting Dropbox solves that ridiculous M$oft lag for me.
But Bill Gates just put 1 billion in SoftBank so all bugs will be gone.
158 additional answers
    2015-07-29T18:47:11+00:00
    Same here...
    2015-07-29T18:49:07+00:00
    Hi Derrik,
    OK, after the last update today, typing and scrolling are way better.
    Good.
    But...
    Word 2016 still has a big impact on energy. More than 50% on the processor.
    There's still work to be done, as I can't use a software all day that is consuming that much.
    Keep it up!
    2015-07-29T19:09:03+00:00
    I edited my reply to include this:
    "I noticed the cursor blinks in a weird fashion while Word does word count. It was weird, the word count on the bottom of the screen increased and decreased a few times, and every time it changed the cursor would blink in a weird way. It took a while for it to count the 3800 words in the document… (at first it showed me more than 10k words, and it kept going up and down until it decided it was done after a minute or so)."
    Does this happen to you too?
    2015-07-29T19:16:16+00:00
    Nope, I didn't notice that behaviour.
    It always take some little time for the word count, but it works OK.
