Powerpoint 2016 Desktop does not scale interface on multi-monitor setups
2015-09-22T17:27:01+00:00
Surprised this bug is not yet fixed from PPT 2013. In does not occur in Word or Outlook.
I have a Surface Pro 3 with an external HD monitor running Windows 10. The Surface screen is scaled to 150% DPI, the HD monitor, which is the main screen, is in native 100% scaling.
Powerpoint 2016 does not scale its windows when it is dragged to the high-res Surface screen, but all the fonts and UI elements remain tiny at 100% size.
2016-09-22T21:29:51+00:00
Hi everyone,
Just wanted to let you know that, at long last, this issue has been fixed.
The current issue of PowerPoint not automatically scaling to different monitor sizes when in edit view is addressed with Windows 10 Anniversary Update version 1607. With the updated fix, PowerPoint will adjust to the correct screen size when dragged to different monitors.
To access this fix, be sure you have Windows 10 version 1607 or later, and PowerPoint version 16.0.7341.2032 or later, released on September 21, 2016 for Current Channel customers.
To get the latest Office updates, click File > Account > Update Options > Update Now.
Again, many thanks for you patience and feedback.
Best,
-Erik, Office Newsroom
2016-08-23T00:35:59+00:00
PowerPoint has fixed this DPI scaling issue in the latest update of Office 2016 and the application now behaves in the same manner as Word and Excel when dragged to a monitor with a different DPI. You will need both the latest PowerPoint update as well as the recent Windows Anniversary update.
The fix will be available to those in the Office Insider program in the next week or two, and will hit general availability by end of September.
Learn more about Office Insiders or join today here:
https://products.office.com/en-us/office-insider
Read more about the DPI scaling improvements in Windows 10 Anniversary Update in this blog post:
https://blogs.technet.microsoft.com/askcore/2016/08/16/display-scaling-changes-for-the-windows-10-anniversary-update/
Note: At this time, the fix is only available for Office 2016 click to run users, but the team is working hard to port this fix to other versions of PowerPoint.
Thanks again for your patience and feedback on this complicated issue.
Emily Tohir
PowerPoint Program Manager
110 additional answers
    2017-02-02T14:30:39+00:00
    I still have the issue of POWERPOINT not automatically scaling.
    2017-02-02T15:15:47+00:00
    For me the update didn't work either. Well done MS.
    But this did!:
    1. Search for powerpnt.exe.manifest in your office 2016 root
    2. Right-click on powerpnt.exe.manifest and change the permission so you can modify the file
    3. Right-click on powerpnt.exe.manifest and open with Wordpad
    4. Change the line
        <dpiAware>True/PM</dpiAware>
        to
        <dpiAware>False/PM</dpiAware>
    1. Save file
    (at least with Office 365, you don't need to do anything in the registry as it's already looking at the external manifest file.)
    Wishing ya'll a lot of success!
    But this did!:
    4. Change the line
        to
    1. Save file
    Like the poster above, I have been modifying the manifest file.  This works safely with no problems across Office or other programs.  Of course, I have to re-do it with each update  - sure wish MS would fix this.
    I can't see why they don't incorporate this fix; I use it to project through digital projectors, to use high res imaging on various external monitors, Photoshop, etc without any issues.  This is up-to-date Win10 and Office, with Surface Pro 4 i7 and a 22" external monitor.
    2017-06-20T11:21:31+00:00
    Is there any solution for the MSI installation?
