Powerpoint 2016 Desktop does not scale interface on multi-monitor setups
2015-09-22T17:27:01+00:00
Surprised this bug is not yet fixed from PPT 2013. In does not occur in Word or Outlook.
I have a Surface Pro 3 with an external HD monitor running Windows 10. The Surface screen is scaled to 150% DPI, the HD monitor, which is the main screen, is in native 100% scaling.
Powerpoint 2016 does not scale its windows when it is dragged to the high-res Surface screen, but all the fonts and UI elements remain tiny at 100% size.
2016-09-22T21:29:51+00:00
Hi everyone,
Just wanted to let you know that, at long last, this issue has been fixed.
The current issue of PowerPoint not automatically scaling to different monitor sizes when in edit view is addressed with Windows 10 Anniversary Update version 1607. With the updated fix, PowerPoint will adjust to the correct screen size when dragged to different monitors.
To access this fix, be sure you have Windows 10 version 1607 or later, and PowerPoint version 16.0.7341.2032 or later, released on September 21, 2016 for Current Channel customers.
To get the latest Office updates, click File > Account > Update Options > Update Now.
Again, many thanks for you patience and feedback.
Best,
-Erik, Office Newsroom
2016-08-23T00:35:59+00:00
PowerPoint has fixed this DPI scaling issue in the latest update of Office 2016 and the application now behaves in the same manner as Word and Excel when dragged to a monitor with a different DPI. You will need both the latest PowerPoint update as well as the recent Windows Anniversary update.
The fix will be available to those in the Office Insider program in the next week or two, and will hit general availability by end of September.
Learn more about Office Insiders or join today here:
https://products.office.com/en-us/office-insider
Read more about the DPI scaling improvements in Windows 10 Anniversary Update in this blog post:
https://blogs.technet.microsoft.com/askcore/2016/08/16/display-scaling-changes-for-the-windows-10-anniversary-update/
Note: At this time, the fix is only available for Office 2016 click to run users, but the team is working hard to port this fix to other versions of PowerPoint.
Thanks again for your patience and feedback on this complicated issue.
Emily Tohir
PowerPoint Program Manager
110 additional answers
    2016-03-25T10:48:06+00:00
    Though, if you use Powerpoint only on the external monitror, this is the solution for you... (but if you unplug the monitor and use PPT on you laptop screen the you'll get the blurry UI)
    I agree, this might work for a very small number of people. People who buy an XPS 13, Surface or Surface Book will be buying it for working while traveling and use in the office (just as we want to)
    If we were going to be happy with poor resolution displays when traveling then we could have spent £500 on a Netbook, rather than £1500+ on an ultrabook.
    I think my eyesight will be effected if I'm reading text like the example shown above!
    2016-04-18T21:37:35+00:00
    Bump* still no resolution from Microsoft.
    2016-04-19T01:41:31+00:00
    Yes, and I find the initial response from Microsoft laughable (it not a bug - its so we can have nice quality presentations).
    Regards
    Sean
