A family of Microsoft products that enable users to capture, organize, and reuse notes electronically.
The fix just went live in the store 15.22.1 Get it here https://app.adjust.com/qncury
Very sorry for the inconvenience.
Hello everyone
I'm using iPad pro with Onenote, i write notes in class with iPad pencil. when i want to erase - its not working.
In order to erase i need to exit the app and re-open it, this is the only way it will erase.
After short while it won't work and i need to re-do those steps again (not really effective...)
Another issue with RTL language:
When i type with the "text mode" Hebrew - everything works fine but after reviewing the notes again - the original text alignment changes and become LTR, in other words i see "mirror of the text" and its not readable.
those are the issues currently i have seen in the Onenote iPad version.
I have uninstalled the app and re-installed it, same issues happened.
Any idea what to do?
General feedback to Microsoft:
It will be great if Microsoft team will make the iPad version the same as Windows version, there are so many functions missing and honestly speaking the current version of Onenote for iOS is not that better from other apps available in app store.
Same with me. Its horrible
Yep - me too - iPad Pro 9.7
Same eraser problem
Here's something that I just tried and seemed to work on my iPad Pro. I went to Settings...OneNote...Reset OneNote option. Then, selected both toggle switches. Closed out OneNote completely and reopened.
I did have to sign in again and allow it to download all of my notebooks again, but the Eraser function is working again. It is a hassle to do and shouldn't have happened, but it's working now.
Kelly.
Guys, I don't update OneNote anymore, unless its a mega update, and only after a week it was released.
As much as I love the app, and dependent on it, at least 40% of all app updates have resulted in it being useless until the next update is available.
Dear Microsoft, you are under-investing in your QA, especially in anything that has to do with RTL. I advise to maintain your great momentum, and allocate budgets, you have built an app that is many people's life/work center, spend more on testing before you release versions.
Thanks!
