Cannot erase after drawing - Onenote for iPad Pro + Typing RTL issues
2016-02-28T09:23:17+00:00
Hello everyone
I'm using iPad pro with Onenote, i write notes in class with iPad pencil. when i want to erase - its not working.
In order to erase i need to exit the app and re-open it, this is the only way it will erase.
After short while it won't work and i need to re-do those steps again (not really effective...)
Another issue with RTL language:
When i type with the "text mode" Hebrew - everything works fine but after reviewing the notes again - the original text alignment changes and become LTR, in other words i see "mirror of the text" and its not readable.
those are the issues currently i have seen in the Onenote iPad version.
I have uninstalled the app and re-installed it, same issues happened.
Any idea what to do?
General feedback to Microsoft:
It will be great if Microsoft team will make the iPad version the same as Windows version, there are so many functions missing and honestly speaking the current version of Onenote for iOS is not that better from other apps available in app store.
2016-05-07T21:26:16+00:00
The fix just went live in the store 15.22.1  Get it here https://app.adjust.com/qncury
Very sorry for the inconvenience.
40 additional answers
    2016-05-04T14:50:47+00:00
    Same here. It was working perfectly last night, May 3rd. Opened it up this morning and, with the eraser selected, it only does a rectangle selection of what I'm trying to erase.
    Not sure what the deal is here. Can Microsoft offer any input into this? Did an over night update to the app cause this?
    If nothing else, May the Fourth be with us.
    2016-05-04T15:18:02+00:00
    same here update last night screwed something up. erase function doesn't work with pencil or by touch.
    2016-05-04T15:41:03+00:00
    Having same problem - downloaded one note to use on IPad Pro with pencil just yesterday (May 3) worked fine last night but isn't erasing today.
    2016-05-04T16:40:51+00:00
    Microsoft: I am now having the same erase problem on iPad pro after latest Onenote update. Please issue another update to fix bug.
