Pictures not showing in printed versions of reports (or in print previews)
2015-09-28T16:28:54+00:00
Hi all,
I have an access acce that i run on two different machines, one of which is in windows 10 /Office 2016, the other one is in Windows 10 / Office 2010. My Acces prints out perfectly on the 2010 version of Access and no image is coming our on the 2016 version on Office (the same Accde was printing perfectly as i had Access 2013 before the weekend) now no image is coming out on the print.
If I look on screen at the report, pictures are there, as soon as I get onto the print preview, images are gone !
This is probably a new feature of access 2016 that I am not aware of !
Can anybody help me ?
Thanks in advance
Marc
Microsoft 365 and Office | Access | For home | Windows
ScottGem 68,840 Reputation points Volunteer Moderator
2015-11-09T18:23:13+00:00
Patrick, I fully understand the affect this has had. And I couldn't agree more that a way of going back should have been made available. But it doesn't really matter how specific the issue is, a fix needed to be found, tested and then implemented within the rollout cycle. As I understand it a potential fix was identified late in October. And the testing made it miss the November cycle. Hence the December release.
153 additional answers
  1. Tom van Stiphout 40,216 Reputation points MVP Volunteer Moderator
    2015-10-02T01:53:16+00:00
    You misunderstood me. I wrote "It may have something to do with the history of the file."
    With that I did not mean age, I meant how it started life as an older version and was upgraded from time to time.
    2015-10-02T13:26:13+00:00
    Tom,
    One of the files I used to test pictures is a brand new (no history) file.
    It is quite small and contains 1 hand typed table and a report.
    The results are exactly the same. Again this runs perfectly on 2013 and not on 2016.
    Have we narrowed this down to the OS or just office version?
  3. Deleted
    2015-10-03T01:26:14+00:00
    This worked for me: I brought the pics into photoshop and saved them under the same name, but as bitmaps.  When I then embedded the bmp version of the pic, it showed up.  That solved it for most of them. Others still did not show, but when I then assigned them back to the original jpg it showed up just fine.  That took care of almost 90% of my embedded pictures, but there are still a few left that aren't showing up...still working at it.  Don't know why this works, but hopefully it helps someone else.
