Pictures not showing in printed versions of reports (or in print previews)
2015-09-28T16:28:54+00:00
Hi all,
I have an access acce that i run on two different machines, one of which is in windows 10 /Office 2016, the other one is in Windows 10 / Office 2010. My Acces prints out perfectly on the 2010 version of Access and no image is coming our on the 2016 version on Office (the same Accde was printing perfectly as i had Access 2013 before the weekend) now no image is coming out on the print.
If I look on screen at the report, pictures are there, as soon as I get onto the print preview, images are gone !
This is probably a new feature of access 2016 that I am not aware of !
Can anybody help me ?
Thanks in advance
Marc
Microsoft 365 and Office | Access | For home | Windows
ScottGem 68,840 Reputation points Volunteer Moderator
2015-11-09T18:23:13+00:00
Patrick, I fully understand the affect this has had. And I couldn't agree more that a way of going back should have been made available. But it doesn't really matter how specific the issue is, a fix needed to be found, tested and then implemented within the rollout cycle. As I understand it a potential fix was identified late in October. And the testing made it miss the November cycle. Hence the December release.
153 additional answers
    2016-01-19T15:23:58+00:00
    I had another client call me today to report Logos gone from Reports and Previews.
    Fortunately I had followed the advice of previous replies to this problem and prepared a front end with all the logos changed from ZOOM to CLIP or STRETCH.
    Problem solved in three minutes and another happy client.
    That's the answer. Change the Zoom to clip or stretch.
    Best of luck
    Andy
    2016-01-22T23:36:04+00:00
    So is this fixed yet?
    2016-02-16T19:54:34+00:00
    Only partially with the work around mentioned to me by AnyWal:
    "I had another client call me today to report Logos gone from Reports and Previews.
    Best of luck
    Andy"
    Other than that fix (which fixed one file for us), images are still not showing correctly in our Access programs.
    2016-03-28T09:03:07+00:00
    All the problems with pictures you have in access can be solved if you save the picture in Windows Paint program. It seems that Windows Paint saves picture in a format, that is readable in access. I also found out, that the best solution is, that I make all the images, logos,...in Windows Paint and then save them. You can also use past option in Windows Paint program to put image files you already have made in a new Windows Paint image file.
    BR and I hope that will help you. It took me months to figure it out ...
